Bossa Program on Duet 2 Wifi
Having this same issue with my Duet 2 Wifi. In my device manager, my board shows up as "Bossa Program Port". When I put the microSD directly into my computer I can see all the firmware there, but it won't recognize the device when I'm trying to connect to it in YAT. This link no longer works, is there an updated way to fix this or should I just swap the most up-to-date "Duet2CombinedFirmware.bin"?
@JRCL The firmware has been deleted, which is why it's showing as a 'Bossa Program Port'. You need to use Bossa to flash the firmware, it doesn't flash from the SD card. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
thanks to @droftarts for pointing me in the right direction. I had to do an additional reset of my computer and board after verifying, then it worked.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
