    Temperature sensor triggering some macro
    • awitcundefined
      awitc
      Hi!
      I am looking for a way to have a specific action triggered by a temperature threshold, to implement some cooling system for one of my tools.
      Whenever a given temperature is reached, I want to enable a pump, which works for a while, and then stops, when a lower threshold is reached. One could say, that I want a 'reverse heater' with bang-bang control.
      I read a lot about macros, but they seem to be usually triggered by something like a button. I am looking for a solution which could monitor the sensor during general printer operation (during printing, idle, etc.), so not only when a given gcode is running.
      Applying a maximum temperature for a sensor also doesn't work, as when the temperature rises to the set value, the firmware detects a fault event.
      I am looking forward to any suggestions on how to handle this issue.
      Best regards,
      AW
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @awitc
        @awitc have a look at using daemon.g. by default it runs every 10 seconds
          dc42 administrators @awitc
          @awitc would configuring the pump as a thermostatic fan work? The downside would be that the temperature difference between the upper and lower thresholds is fixed.
          • awitcundefined
            awitc
            Thank you for your replies @jay_s_uk and @dc42. Both suggestions seem to be valid solutions. I will firstly look more into the daemon.g file, as it is more customizable and fitting for my purpose.
            • infiniteloopundefined infiniteloop referenced this topic
