    Mysterious Z150!
    • handyandyundefined
      handyandy
      Hi I am trying to find a Z150 command that gets executed every time I start print.
      I have looked in the Cura startup code, start.g and pretyty well everywhere else!
      What is the start sequence of files called when starting a print? Or could this be in the firmware?
        jay_s_uk @handyandy
        @handyandy start.g is executed before anything else and then its whatever is contained within the gcode file
        handyandyundefined ctilley79undefined 2 Replies Last reply Reply Quote 0
          handyandy @jay_s_uk
          @jay_s_uk Thanks for that.
          handyandyundefined 1 Reply Last reply Reply Quote 0
            handyandy @handyandy
            @handyandy This still does not explain why when starting a print the nozzle goes up to Z150 (shown on the console) There is not one mention of Z150 anywhere in the macros, system files that I cant find!
            Still puzzled... must be in the firmware coding?
              jay_s_uk @handyandy
              @handyandy post your homeall, homez, first lines of your gcode file up to the point it starts extruding and anything else thats called
              • ctilley79undefined
                ctilley79 @jay_s_uk
                @jay_s_uk This is somewhat related, but can you send parameters from your slicer start code to /sys/start.g? The only way I've found to do it so far is to create a separate macro and call that via
                M98 P"/macros/whatever.g" H[hotend_temp] B[bed_temp]
                However there doesn't seem to be a way to pass that parameter to the start.g in the sys folder that is executed automatically.
                  jay_s_uk @ctilley79
                  @ctilley79 you can't send parameters to start.g as it's executed before the gcode is
