    EMERGENCY STOP
    • matej1006undefined
      matej1006
      Hello
      i can't figurit out what is wrong
      i would also like to when is pressed emergency that i get output activated.
      this is my config.g code
      ; Emergen1cy Stop ##################4##################################################################################
      M950 J1 C"io0.in"               			; Define Emergency endstop - emergency stop switch condition
      M950 P0 C"io0.out"
      M581 P1 S0 T1                   			; Define action to be taken with activation of emergency stop switch
      M582 T1 S1 									; set trigger #3 pending unconditionally
      and this trigger1.g
      ;trigger1.g
      M999
      M42 P0 S1
      nothing happend when i press
      i have 3.3V to com and NC back to input with 10Kohm ressistor to gnd
        https://docs.duet3d.com/User_manual/Reference/Gcodes#m999-restart
        M999 resets the firmware, you can't execute the command after that because the firmware is reset. If you need M42 P0 S1 to happen, move it before M999.
        matej1006undefined 1 Reply Last reply Reply Quote 0
          matej1006 @Phaedrux
          @Phaedrux yeah i know that i mean M112.
          but why i don't get any input reading
          also i have problem on 1HCL i can't read end stop for tool locking mech.
          i have two micro switch in serias with NC. And when i press on end stop switch nothing happend od DWC.
          I have problem with input's and output's.
          • deckingmanundefined
            deckingman @matej1006
            @matej1006 You can't use a macro tigger1. From the docs quote..............
            "Trigger number 0 causes an emergency stop as if M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater than 1 causes the macro file sys/trigger#.g to be executed."
            So trigger1 will cause the print to be paused but it won't run your macro. You need to use a trigger number higher than 1 in order to run your own trigger macro.
            As for your other issues - these are unrelated to the topic title so best to start a new thread. When you do, post your entire config.g file in that thread.
