Solved Delete existing Wi-Fi
Hi. I am using DUET2 Wifi product.
I connected the Wi-Fi and used it, but the Wi-Fi was no longer available as I moved the equipment.Is there a way to remove existing Wi-Fi?
I have a headache because of the constant alarm. -
Thank you for your reply.
I tried M588 S"*" but it is reported as below.
Is there any other way?
"Failed to reset the WiFi module to factory setting" -
@Kang-Geon-Han-0 try sending
M552 S0
before sending the M588 -
@Kang-Geon-Han-0 the command may have worked despite the error message. Try sending M552 S0 followed by M587 to list the known wifi networks.
@Kang-Geon-Han-0 try sending M552 S-1 followed by M552 S0, then try M587 again. If that doesn't work then I suggest you download DuetWiFiServer version 1.27 from recent RRF release, copy it into /firmware or /sys on your SD card (depending on your RRF version)_, and use M997 S1 to re-install it.
Is this right?
I'm confused because the version is not written.
I'll update it to M997.
@Kang-Geon-Han-0 yes, if you are running RRF 3.5.0 beta 4 then that is the correct file.
Thank you.
It was solved without any particular problem because I did it in the way you told me. -
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
