Inverting Logic on Error Pin
I am trying to invert the Duet 3 Main 6XD WD1256 Board logic for the error pin on the driver slots.
Is this a possibility via the config.g file within the duet interface?
; Setting logic of the error pins to be on standby when first turning the duet on - prevents accidents M569 P0.2.4 R1 The intention of this via searching the web was to change the logic on drive number 2 and pin 4 with the R1 command to invert the logic.
@elmw you can't use M569 for that.
The documentation is here:
https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview#description-of-connections
