    Proximity sensor for rotary home switch
    • jimakronundefined
      jimakron
      I have a Duet3 mini5+, using a PNP NC proximity sensor currently using the IO_3.in using the 5V_EXT, GND and IN pin.
      The sensor has a light that is lit when not sensing anything and 5V is read from this. When sensing, the light goes out and it goes to 0V.
      My config for it is M574 A1 S1 P"!io3.in".
      The axis rotates according to the homea.g file, but never stops at switch.
      I've searched for an answer but have not found any.
      Anyone have any ideas as to why it isn't stopping at the home switch?
        dc42 administrators @jimakron
        @jimakron to connect a PNP sensor to a Duet you normally need to use a voltage divider or at least a pulldown resistor. See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#pnp-output-normally-open-inductive-or-capacitive-sensor.
        jimakronundefined 1 Reply Last reply Reply Quote 0
        • jimakronundefined
          jimakron @dc42
          @dc42 Thank you!
          I switched to the NPN NO sensor.
          Am I still able to use this in the IO_3? Connecting the ground to the IO_3 GND, the power to 12/24v supply, and the signal to IO_3 IN? Still using the same config? M574 A1 S1 P"!io3.in"?
          TIA
            @jimakron yes that looks correct to me.
            • jimakronundefined
              jimakron @dc42
              @dc42 Thank you so much
              • jimakronundefined jimakron marked this topic as a question
              • jimakronundefined jimakron has marked this topic as solved
