phase A may be disconnected, phase B may be disconnected error
Warning: Driver 3 warning: phase A may be disconnected, phase B may be disconnected
getting this error when trying to use extruder. I have looked at past forum post and could not find a probable cause for the issue
this only happens at one baud rate, at any other it does not extrude still but it doesnt have the error
@Drainer are you sure that you have connected the extruder motor to the correct stepper motor output on the Duet?
@dc42 I figured it out, it was not, I followed the guide for the printer, but that was wrong, thank you!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
