    MCU Temp Duet 3 Expansion EXP3HC?`
    Gcode meta commands
    • Zsevenundefined
      Zseven
      Hello , how can I include the MCU temperature from the Duet 3 Expansion EXP3HC?`
      • marvineerundefined
        marvineer
        this works by adding this line to your config.g:
        M308 S6 Y"mcu-temp" P"1.dummy" A"3HC MCU"                            ;show MCU-temp of CAN expansion board 1 (3HC) in DWC (Tools -> Extra) Graph
        Note: Here you find the docs for M308.
        You have to adjust
        • the sensor number S (6 in my case but maybe allready taken in your setup)
        • the CAN address of your EXP3HC in P (1 in my case but probably different in your setup)
        Zsevenundefined 1 Reply Last reply Reply Quote 0
        • Zsevenundefined
          Zseven @marvineer
          Thank You !
