    Duet 2 wifi power supply squeal
    • trucker2215undefined
      trucker2215
      Please help my duet 2 WIFI heats the bed and hot end with out a problem but when trying to maintain the bed temp the power supply squeaks extremely bad i've tried using with 12v and a 24v power supply but it still has problems! Video attached
      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @trucker2215
        @trucker2215 You can use Bang-Bang mode for the bed heater. Some say it will show in your print, because the bed will bend. But that depends on the flexibility of the bed mounting ( search kinematic bed ) and thickness of the heat spreader.
        trucker2215undefined 1 Reply Last reply Reply Quote 0
          Have you PID tuned the bed heater and what PWM frequency are you using? Post your config.g
            dc42 administrators @trucker2215
            @trucker2215 it sounds to me that the PWM frequency you are using for the bed heater is too high.
              trucker2215 @o_lampe
              @o_lampe I switch to bang bang and it went away Thank you guys so much for your help this was really annoying
                @trucker2215 using bang-bang mode for a bed heater often results in Z banding. If you experience that then I suggest you try using a low PWM frequency instead.
