Solved how to separate the tool fan from the part cooling fan
im having a problem whit the part cooling fan controlling also the tool fan how i can separate the two
so i can keep the tool fan always at 100%?
the problem is my gcode or the settings of my system?
the two seems linked togheder if i move the firts one the second does the same and vice versa.
@Simone the tool fan is the part cooling fan of the currently active tool and not the hot end cooling fan
You can click on Change Visibility and hide one of them if you wish.
