    Input Shaper Plugin Requires Dummy Axis to be Homed
    Plugins for DWC and DSF
    input shaper idex
    727
    • curieosundefined
      curieos
      Our machine is setup with independent Y motors, and in order to adjust for inaccuracies in the endstop positions, I have it setup to split the Y axis into Y and V after homing, moving the V motor to tram the Y gantry, and then recombining them post-homing.
      I think this is causing issues with the Input Shaper plugin where it doesn't recognize the machine as being fully homed. Is there a way to deal with this?
      edit: I think I miscategorized this, I think it should be in plugins for DWC. Can someone please move this?
      She/Her
      I work at a local 3D printing shop.
      Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
      p8blrundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • p8blrundefined
        p8blr @curieos
        @curieos Shouldn't have to split up your axes with multiple endstops configured in M574
        M574 Y1 S1 P"0.io2.in+0.io3.in"
        M574 docs page
          jay_s_uk @p8blr
          @p8blr you will if you need to adjust for skew. There's no way to do it when there are multiple endstop combined
          p8blrundefined 1 Reply Last reply Reply Quote 1
          • p8blrundefined
            p8blr @jay_s_uk
            @jay_s_uk Not sure how you're adjusting the axes, but it will compensate for skew if you have adjustable endstops.
            Something like this:
            curieosundefined 1 Reply Last reply Reply Quote 0
            • curieosundefined
              curieos @p8blr
              @p8blr The endstops do not have adjustment, nor do we have provisions in the design for this. Besides, I prefer making the endstop mount rigidly and compensating for minor inaccuracies with software adjustments. This method is more repeatable in my experience.
              She/Her
              • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
                Phaedrux Moderator @curieos
                @curieos said in Input Shaper Plugin Requires Dummy Axis to be Homed:
                What exactly are you seeing in the plug?
                What gcode commands are you using to split and combine the axis?
                • curieosundefined
                  curieos @Phaedrux
                  @Phaedrux
                  All axes are homed, minus the hidden V that has no motors assigned.
                  homey.g looks like this:
                  var LY_driver = move.axes[1].drivers[0]
                  var RY_driver = move.axes[1].drivers[1]
                  G91											; relative positioning
                  G1 H2 Z5 F3000								; lift Z relative to current position
                  G1 H1 Y-655 F6000							; move quickly to Y axis endstop and stop there (first pass)
                  G1 H2 Y5 F3000								; go back a few mm
                  G1 H1 Y-10 F360								; move slowly to Y axis endstop once more (second pass)
                  M584 Y2.2 V2.3 P5							; separate Y axis into two axes
                  M584 Y{var.LY_driver} V{var.RY_driver} P5	; separate Y axis into two axes
                  M92 V{move.axes[1].stepsPerMm}				; set new axis steps per mm
                  M564 H0										; allow movement without homing to square
                  G1 H2 V{global.y_axis_skew}					; square Y by moving V
                  M584 Y{var.LY_driver, var.RY_driver} V P4	; rejoin Y axis and hide U from UI
                  G1 H2 Z-5 F3000								; lower Z again
                  M564 H1										; enforce axis minimums and maximums and only allow movement after homing
                  G90											; absolute positioning
                  She/Her
                    What does M119 show for endstop states when you get that error?
                    Can you try sending the lines from your homing file one at a time? Do you get any errors?
                    I also see you're using a mix of U and V. Do you also have a U axis?
                    • curieosundefined
                      curieos @Phaedrux
                      @Phaedrux To be clear, I'm not having any issues homing. No errors are encountered at any point. Everything works perfectly, the only issue is the IS plugin won't allow me to record motion profiles because it thinks the machine is not fully homed.
                      It's an IDEX printer, so the secondary toolhead is the U axis. It also has a euclid as Z-probe, so that displays as being triggered when it's not deployed since it's NC. 0e7d3ee9-058e-4add-ab4e-2f7501636ad7-image.png
                      She/Her
                        As a work around can you try unmapping the V endstop with an M574 command in your homing file after it's been hidden? Or try adding an M92 V command to force it to be marked as homed?
                        • curieosundefined
                          curieos @Phaedrux
                          @Phaedrux Do you mean G92? M92 sets axis steps per mm.
                          She/Her
                            @curieos Yes, sorry, G92
                            • curieosundefined
                              curieos @Phaedrux
                              @Phaedrux That doesn't seem to work. I was looking in the model browser, and it wasn't updating user workspace coordinates for that axis though. I added it to the homing macros, and I tried running it in the console and it didn't seem to do anything. I can try again when I get into work.
                              She/Her
                              • curieosundefined
                                curieos @curieos
                                @Phaedrux It's working now. Not sure what changed, but I did put it in a slightly different place this time.
                                She/Her
