    Running filament config.g on IDEX in duplication mode
    idex macros
    • curieosundefined
      curieos
      I have T2 configured as "duplicator" mode, and I'm trying to figure out how to run the config.g for the loaded filament. Since it's configured as a "mixing extruder" with multiple drives, I'm assuming RRF won't allow me to set it as loaded with a filament, but the tools that make up T2 are loaded with filaments. Is there an established way of running the config.g in tpost2.g?
      She/Her
      I work at a local 3D printing shop.
      Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
      • o_lampeundefined
        o_lampe @curieos
        @curieos It's unusual to define two independent toolheads as mixing extruder.
        Why not define two toolchains with separate thermistor, heater, fans and extruder?
        As a sidenote, I'd use mirror mode instead of copy mode. It eliminates the inertia of two toolheads swaying around...
        curieosundefined 1 Reply Last reply Reply Quote 0
        • curieosundefined
          curieos @o_lampe
          @o_lampe Unless this is outdated, this is the intended configuration as per: https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_IDEX
          T0 and T1 exist separately as their own tools. They are joined together into tool 2, as per the documentation:
          M563 P2 D0:1 H1:2 X0:3 F2:3 S"Duplicator"	; define tool 2, "duplicator mode"
          G10 P2 X0 Y0 U-320 S0 R0			; set tool offsets and temperatures
          G10 P2 R0 S0					; set initial tool 1 active and standby temperatures to 0C
          M567 P2 E1:1					; set mix ratio 100% on both extruders
          Mirror mode is not always useful. Sometimes you want two of the exact same part, and they are not symetrical.
          She/Her
          • o_lampeundefined
            o_lampe @curieos
            @curieos said in Running filament config.g on IDEX in duplication mode:
            If you use mirror mode you have to set kinematic matrix and the bed coordinates accordingly. Then you can print anything that's not symetrical
            • curieosundefined
              curieos @o_lampe
              @o_lampe Okay, then link me to where I can find out more.
              She/Her
              • curieosundefined
                curieos @curieos
                @curieos I found the answer to my own question. https://docs.duet3d.com/User_manual/Reference/Gcodes#m563-define-or-remove-a-tool I can use the L parameter to set which drive to map filament to.
                She/Her
                • dc42undefined dc42 marked this topic as a question
