No connection to yat - Keine Verbindung zu YAT möglich
Hello
Is there a new driver for Windows 11? For duet 2 wifi.
I can't get rid of the yellow triangle at COM3... (error code 10, comport can not start). YAT does not recognize the PORT.
This means that no connection can be established with the board.!Hallo
Gibt es vielleicht einen neuen Treiber für Windows 11?
Ich bekomme das gelbe Dreieck bei COM3 nicht weg... (Fehler Code 10). YAT erkennt den PORT nicht.
Somit kann auch keine Verbindung mit dem Board hergestellt werden.
Danke, Manfred -
No new driver.
Have you used the firmware erase jumper?
Have you tried a different USB port/cable? Do you have a USB hub you can use?
Is this a new board? Was it working previously?
thanks for the good will to help.
I ran "erase" after an update destroyed everything. before everything ran perfectly with old firmware. I was able to solve the problem last night. with bossa I was able to upload a new firmware. with that "yat" could connect and i brought the board back to life. now i just have to renew all the obsolete commands. I'm in good spirits that everything will be back to normal soon...
best regards, manfred -
