truncated M591 response in console
@Adrian52 thanks for your report. We will try to reproduce it.
@dc42 Thank you. As there were no other immediate replies, I checked in 3.4.6, and the problem went away. Installing a fresh download 3.5rc1 and the problem came back. Perhaps should add I am running a fairly old duet2wifi - 1.01 I think.
@Adrian52 thanks. The M591 response is longer in 3.5.0-rc.1 than it was previously, so it is entirely possible that it no longer fits in the buffer available for it.
@dc42 confirmed this is being truncated early:
M591 D1 Duet3D rotating magnet filament monitor v3 on pin 10.io1.in, enabled when printing from SD card, sensitivity 24.80mm/rev, allow 40% to 120%, check printing moves every 2.0mm, version 3, mag 134 agc 0, measured sensitivity 24.66mm/rev, min 95% max 105% over
@Adrian52 this is logged as issue:
The latest rc1+(from 31/10/2023) is still a little bit truncated:
Duet3D laser filament monitor v2 on pin (connlcd.encb,connlcd.3), enabled when SD printing, allow 1% to 300%, check all extruding moves every 10.0mm, calibration factor 0.398, quality 222, brightness 41, shutter 140, measured min 80% avg 101% max 120% over
@Adrian52 thanks, I'll abbreviate it some more.
@Adrian52 which Duet are you using?
@dc42 I have an early (1.01) duet 2wifi
@Adrian52 thanks. Please try the new firmware binary for Duet 2 at https://www.dropbox.com/scl/fo/tjznycpk7bv7sj71p0ssl/h?rlkey=096p4nvgmigyrb20jj8olg3wu&dl=0. I have moved the brightness and shutter value reports to the M122 report; so please check the Filament Monitors section of the M122 report as well as the M591 response. I don't have a version 3 laser filament monitor in a machine at present so I can't complete these tests myself.
@dc42 Thank you. The M591 response looks fine now:
Duet3D laser filament monitor v2 on pin (connlcd.encb,connlcd.3), enabled when SD printing, allow 1% to 300%, check all extruding moves every 10.0mm, cal. factor 0.398, quality 223, measured min 100% avg 101% max 103% over 1400.3mm
This is the M122 after the test print
m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.1+ (2023-11-01 10:30:19) running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W Used output buffers: 3 of 26 (26 max) === RTOS === Static ram: 23084 Dynamic ram: 74860 of which 0 recycled Never used RAM 14264, free system stack 112 words Tasks: NETWORK(2,nWait,15.5%,214) HEAT(3,nWait,0.1%,310) Move(4,nWait,1.1%,261) MAIN(1,running,83.3%,851) IDLE(0,ready,0.0%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:31:22 ago, cause: software Last software reset at 2023-10-22 17:39, reason: User, Gcodes spinning, available RAM 9544, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 29.6, current 32.7, max 34.3 Supply voltage: min 24.1, current 24.4, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min 0 Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-11-01 21:40:28 Cache data hit count 4294967295 Slowest loop: 217.89ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.8ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 39, maxWait 271969ms, bed compensation in use: none, height map offset 0.000, ebfmin -0.99, ebfmax 1.00 no step interrupt scheduled Moves shaped first try 1911, on retry 173, too short 353, wrong shape 466, maybepossible 58 === DDARing 0 === Scheduled moves 3691, completed 3691, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 7], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === check 3500690 clear 3025120 Extruder 0: pos 5.47, brightness 36, shutter 128, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0=== Network === Slowest loop: 207.47ms; fastest: 0.07ms Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address 5c:cf:7f:2c:24:6b Module reset reason: Turned on by main processor, Vcc 3.38, flash size 2097152, free heap 42952 WiFi IP address 192.168.1.16 Signal strength -55dBm, channel 13, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 3 0 0 0 0 0
I think the filament sensor output needs a cr/lf at the end?
I just printed a plain cube, but it came out dimensionally correct and no y slope!
Thank you again.
@Adrian52 thanks, I've added that newline.
