Duet3 6XD based 3D printer freezes mid-print, then continues
Hi!
I am experiencing an issue, where my 3D printer performs well during the majority of the print, then at some point, it stops (both movements and extrusion), and after 5-10 seconds continues as if nothing happened. This can happen more than once, but the gaps between occurrences are fairly large, ie. 10-30 minutes.
This is not related to one specific gcode file (gcode looks alright) or part printed, and it occurs at different heights. My only suspicion is that the printer is processing a certain length of gcode and stops when it gets a new 'batch'.
I saw some similar posts asking about microstepping settings, here are mine:
M350 X32 Y32 Z32 E16 I0 ; microstepping with/without interpolation Best regards,
AW -
@awitc what firmware version are you running?
best grab an M122 output when the issue next occurs -
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.4.6 (2023-07-21 14:11:58) running on Duet 3 MB6XD v1.0 (SBC mode) Board ID: 08DLM-956DA-M24S4-7JKD0-3SJ6P-1BJLU Used output buffers: 1 of 40 (15 max) === RTOS === Static ram: 151692 Dynamic ram: 67564 of which 0 recycled Never used RAM 128416, free system stack 154 words Tasks: SBC(ready,0.7%,487) HEAT(notifyWait,0.1%,346) Move(notifyWait,0.3%,267) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,352) MAIN(running,98.8%,1125) IDLE(ready,0.1%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:02:50 ago, cause: software Last software reset at 2023-09-06 11:57, reason: User, GCodes spinning, available RAM 128416, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 18721 MCU temperature: min 36.3, current 36.6, max 36.8 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.8, current 11.9, max 12.3, under voltage events: 0 Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/44/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Driver 5: ok Date/time: 2023-09-06 12:00:47 Slowest loop: 53.01ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 6, maxWait 60052ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 291, completed 291, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 8 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.3 Heater 2 is on, I-accum = 0.3 Heater 3 is on, I-accum = 0.3 Heater 4 is on, I-accum = 0.0 Heater 5 is on, I-accum = 0.0 Heater 6 is on, I-accum = 0.0 Heater 8 is on, I-accum = 0.1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X211.673004 Y236.014999 Z2.770000 E0.691060" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 1177, received 2085, lost 0, boc 0 Longest wait 1ms for reply type 6013, peak Tx sync delay 8, free buffers 50 (min 49), ts 649/649/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 7327/7327 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b55c Buffer RX/TX: 1704/3216-0, open files: 0 === Duet Control Server === Duet Control Server v3.4.6 File /opt/dsf/sd/gcodes/correct_temps.gcode is selected, processing HTTP: Buffered code: M25 ==> 24 bytes File: Buffered code: G1 X211.673 Y236.015 Z2.77 E0.69106 Buffered code: G1 X211.01 Y235.162 Z2.78 E0.67377 Buffered code: G1 X210.404 Y234.269 Z2.79 E0.67305 Buffered code: G1 X209.849 Y233.331 Z2.8 E0.67972 Buffered code: G1 X209.358 Y232.367 Z2.81 E0.67469 Buffered code: G1 X208.929 Y231.375 Z2.82 E0.67404 Buffered code: G1 X208.555 Y230.336 Z2.83 E0.68868 Buffered code: G1 X208.256 Y229.308 Z2.84 E0.66768 Buffered code: G1 X208.017 Y228.242 Z2.85 E0.68132 Buffered code: G1 X207.848 Y227.172 Z2.86 E0.67558 Buffered code: G1 X207.745 Y226.087 Z2.87 E0.67971 Buffered code: G1 X207.711 Y225 Z2.88 E0.67824 Buffered code: G1 X207.745 Y223.912 Z2.89 E0.67887 Buffered code: G1 X207.847 Y222.831 Z2.9 E0.67716 Buffered code: G1 X208.016 Y221.76 Z2.91 E0.6762 Buffered code: G1 X208.255 Y220.694 Z2.92 E0.68132 Buffered code: G1 X208.554 Y219.666 Z2.93 E0.66768 Buffered code: G1 X208.928 Y218.627 Z2.94 E0.68868 Buffered code: G1 X209.357 Y217.635 Z2.95 E0.67404 Buffered code: G1 X209.848 Y216.671 Z2.96 E0.67469 Buffered code: G1 X210.403 Y215.733 Z2.97 E0.67972 Buffered code: G1 X211.009 Y214.84 Z2.98 E0.67305 Buffered code: G1 X211.672 Y213.987 Z2.99 E0.67377 Buffered code: G1 X212.404 Y213.154 Z3 E0.69158 Buffered code: ;LAYER:2 Buffered code: ;MESH:budVase.stl Buffered code: G1 X213.15 Y212.399 Z3.01 E0.66194 ==> 1488 bytes Pending code: G1 X213.977 Y211.661 Z3.02 E0.69126 Pending code: G1 X214.828 Y210.992 Z3.029 E0.67509 Pending code: G1 X215.718 Y210.38 Z3.039 E0.67362 Daemon: Buffered code: G4 S1 ==> 32 bytes Executing macro daemon.g, started by system Number of flush requests: 1 > Next stack level Code buffer space: 1704 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 39.45, max time between full transfers: 38.9ms, max pin wait times: 34.1ms/0.1ms Codes per second: 2.73 Maximum length of RX/TX data transfers: 3778/1664 -
After a second occurence during the same print:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.4.6 (2023-07-21 14:11:58) running on Duet 3 MB6XD v1.0 (SBC mode) Board ID: 08DLM-956DA-M24S4-7JKD0-3SJ6P-1BJLU Used output buffers: 1 of 40 (15 max) === RTOS === Static ram: 151692 Dynamic ram: 67564 of which 0 recycled Never used RAM 128416, free system stack 154 words Tasks: SBC(ready,0.8%,487) HEAT(notifyWait,0.1%,346) Move(notifyWait,1.4%,250) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,349) MAIN(running,97.7%,1125) IDLE(ready,0.0%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:10:45 ago, cause: software Last software reset at 2023-09-06 11:57, reason: User, GCodes spinning, available RAM 128416, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 18554 MCU temperature: min 36.5, current 37.4, max 37.6 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.8, current 11.9, max 12.3, under voltage events: 0 Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/44/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Driver 5: ok Date/time: 2023-09-06 12:08:42 Slowest loop: 49.69ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 6, maxWait 69618ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 5478, completed 5451, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 8 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.2 Heater 2 is on, I-accum = 0.1 Heater 3 is on, I-accum = 0.2 Heater 4 is on, I-accum = 0.0 Heater 5 is on, I-accum = 0.0 Heater 6 is on, I-accum = 0.0 Heater 8 is on, I-accum = 0.2 === GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X217.852005 Y226.837006 Z56.861000 E0.577180" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 4277, received 7604, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 9, free buffers 50 (min 50), ts 2376/2376/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 26042/26042 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b55c Buffer RX/TX: 1512/2968-0, open files: 0 === Duet Control Server === Duet Control Server v3.4.6 File /opt/dsf/sd/gcodes/correct_temps.gcode is selected, processing File: Buffered code: G1 X217.852 Y226.837 Z56.861 E0.57718 Buffered code: G1 X217.681 Y225.923 Z56.881 E0.58002 Buffered code: G1 X217.639 Y225.463 Z56.891 E0.28813 Buffered code: G1 X217.641 Y224.539 Z56.911 E0.57637 Buffered code: G1 X217.761 Y223.613 Z56.931 E0.58244 Buffered code: G1 X217.863 Y223.164 Z56.94 E0.2872 Buffered code: G1 X218.152 Y222.289 Z56.96 E0.5748 Buffered code: G1 X218.545 Y221.46 Z56.98 E0.57227 Buffered code: G1 X219.051 Y220.667 Z57 E0.58677 Buffered code: ;LAYER:56 Buffered code: ;MESH:budVase.stl Buffered code: G1 X219.647 Y219.972 Z57.02 E0.5711 Buffered code: G1 X219.976 Y219.627 Z57.03 E0.29736 Buffered code: G1 X220.677 Y219.052 Z57.05 E0.56555 Buffered code: G1 X221.455 Y218.562 Z57.07 E0.57353 Buffered code: G1 X221.871 Y218.365 Z57.08 E0.28712 Buffered code: G1 X222.73 Y218.026 Z57.1 E0.57604 Buffered code: G1 X223.621 Y217.8 Z57.121 E0.5734 Buffered code: G1 X224.536 Y217.673 Z57.141 E0.57622 Buffered code: G1 X225.452 Y217.675 Z57.161 E0.57138 Buffered code: G1 X226.373 Y217.792 Z57.181 E0.57911 Buffered code: G1 X227.266 Y218.036 Z57.201 E0.57745 Buffered code: G1 X228.121 Y218.378 Z57.221 E0.57441 Buffered code: G1 X228.533 Y218.578 Z57.231 E0.28568 Buffered code: G1 X229.309 Y219.072 Z57.251 E0.57381 Buffered code: G1 X230.027 Y219.672 Z57.272 E0.58367 Buffered code: G1 X230.324 Y219.983 Z57.281 E0.26824 ==> 1488 bytes Pending code: G1 X230.922 Y220.694 Z57.302 E0.57953 Pending code: G1 X231.412 Y221.472 Z57.322 E0.57353 Pending code: G1 X231.611 Y221.883 Z57.332 E0.28484 Daemon: Buffered code: G4 S1 ==> 32 bytes Executing macro daemon.g, started by system Number of flush requests: 1 > Next stack level Code buffer space: 1376 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 39.38, max time between full transfers: 47.7ms, max pin wait times: 47.1ms/2.2ms Codes per second: 11.33 Maximum length of RX/TX data transfers: 3778/1664 -
@awitc one for @chrishamm
I've changed the SD card for the new one, however, during the first test print the issue occured again, here is the M122 result, done right after it paused and resumed:
8.09.2023, 12:34:59 M122 === Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.4.6 (2023-07-21 14:11:58) running on Duet 3 MB6XD v1.0 (SBC mode) Board ID: 08DLM-956DA-M24S4-7JKD0-3SJ6P-1BJLU Used output buffers: 1 of 40 (15 max) === RTOS === Static ram: 151692 Dynamic ram: 67564 of which 0 recycled Never used RAM 128416, free system stack 154 words Tasks: SBC(ready,0.6%,487) HEAT(notifyWait,0.1%,346) Move(notifyWait,0.2%,252) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,349) MAIN(running,99.0%,1232) IDLE(ready,0.1%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:20:18 ago, cause: software Last software reset at 2023-09-08 12:14, reason: User, GCodes spinning, available RAM 131648, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 18681 MCU temperature: min 37.3, current 39.0, max 39.1 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.8, current 12.2, max 12.4, under voltage events: 0 Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/54/10, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Driver 5: ok Date/time: 2023-09-08 12:34:58 Slowest loop: 55.53ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 6, maxWait 551121ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 1345, completed 1320, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 8 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.3 Heater 2 is on, I-accum = 0.2 Heater 3 is on, I-accum = 0.3 Heater 4 is on, I-accum = 0.0 Heater 5 is on, I-accum = 0.0 Heater 6 is on, I-accum = 0.0 Heater 8 is on, I-accum = 0.1 === GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X244.630997 Y217.218002 Z13.319000 E0.823970" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is doing "G4 S30" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 10972, received 19471, lost 0, boc 0 Longest wait 1ms for reply type 6018, peak Tx sync delay 389, free buffers 50 (min 49), ts 6091/6090/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 33732/33732 SPI underruns 0, overruns 0 State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x2b584 Buffer RX/TX: 3616/1704-3688, open files: 0 === Duet Control Server === Duet Control Server v3.4.6 File /opt/dsf/sd/gcodes/CFFFP_budVase.gcode is selected, processing File: Buffered code: G1 X244.631 Y217.218 Z13.319 E0.82397 Buffered code: G1 X245.087 Y218.482 Z13.33 E0.83802 Buffered code: G1 X245.455 Y219.748 Z13.34 E0.82221 Buffered code: G1 X245.745 Y221.039 Z13.349 E0.82518 Buffered code: G1 X245.954 Y222.354 Z13.36 E0.83039 Buffered code: G1 X246.08 Y223.673 Z13.369 E0.82633 Buffered code: G1 X246.122 Y225 Z13.379 E0.82799 Buffered code: G1 X246.082 Y226.327 Z13.389 E0.82795 Buffered code: G1 X245.958 Y227.647 Z13.399 E0.82684 Buffered code: G1 X245.751 Y228.962 Z13.41 E0.8302 Buffered code: G1 X245.464 Y230.253 Z13.419 E0.82478 Buffered code: G1 X245.096 Y231.522 Z13.429 E0.82401 Buffered code: G1 X244.642 Y232.786 Z13.44 E0.8376 Buffered code: G1 X244.117 Y234 Z13.45 E0.82487 Buffered code: G1 X243.524 Y235.166 Z13.459 E0.81581 Buffered code: G1 X242.837 Y236.33 Z13.47 E0.84293 Buffered code: G1 X242.102 Y237.413 Z13.479 E0.81626 Buffered code: G1 X241.275 Y238.48 Z13.49 E0.84191 Buffered code: G1 X240.412 Y239.46 Z13.499 E0.81437 Buffered code: G1 X239.469 Y240.408 Z13.509 E0.8339 Buffered code: G1 X238.476 Y241.283 Z13.519 E0.8254 Buffered code: G1 X237.416 Y242.106 Z13.53 E0.83693 Buffered code: G1 X236.334 Y242.842 Z13.539 E0.81609 Buffered code: G1 X235.17 Y243.532 Z13.55 E0.84389 Buffered code: G1 X234.004 Y244.127 Z13.559 E0.81637 Buffered code: G1 X232.79 Y244.653 Z13.569 E0.82512 Buffered code: G1 X231.527 Y245.109 Z13.58 E0.83743 ==> 1512 bytes Pending code: G1 X230.257 Y245.479 Z13.59 E0.82496 Pending code: G1 X228.966 Y245.768 Z13.599 E0.82505 Pending code: G1 X227.649 Y245.978 Z13.61 E0.83172 Pending code: G1 X226.328 Y246.104 Z13.62 E0.82757 Pending code: G1 X225 Y246.146 Z13.63 E0.82861 Daemon: Buffered code: G4 S30 ; wait 30 seconds Buffered code: M106 P3 S0 ; disable fans Buffered code: G4 S1 ==> 104 bytes Executing macro daemon.g, started by system Number of flush requests: 1 > Next stack level Code buffer space: 1856 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 38.67, max time between full transfers: 74.3ms, max pin wait times: 64.8ms/5.6ms Codes per second: 1.87 Maximum length of RX/TX data transfers: 3772/1392 -
I tried such microsteps:
M350 X16 Y16 Z16 E16 I1
but the same problem, back to back, in short time interval, in the middle of the print. Also I find the printer to be way louder in this interpolation mode.
I might have tracked the issue down, asked a question with more information here. If my daemon.g was the culprit, sorry for the waste of time.
