Duet 3 Mainboard 6XD DXF/DWG file request.
Hello all,
I am working on a wiring diagram for a large scale 3D printer designed for concrete printing. The software I am using to make the 2D drawing (SkyCAD) allows DXF or DWG files to be imported into the drawing. I am using the Duet 3 Mainboard 6XD and the expansion board both need to be included in the diagram. The wiring diagram will be a technical document used for CE and UL certification. Hope to hear back soon.
Best regards,
David Summerlin -
@DavidSummerlin can you create the DXF from the step file at https://github.com/Duet3D/Duet3-Mainboard-6XD/tree/master/v1.0 ?
