Heater 1 fault: failed to read sensor: sensor open circuit
Hi, I encountered a problem, can you help me? Thanks..
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.6 (2023-07-21)
Duet WiFi Server Version: 1.27Blv mgn cube
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Jul 22 2020 15:16:47 GMT+0300 (GMT+03:00); General preferences
M550 P"Battal 3D" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M584 X1 Y0 Z2 E3 ; set drive mapping
M92 X100.00 Y100.00 Z800.00 E435.00 ; set steps per mm
M566 X2800.00 Y2800.00 Z12.00 E3600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z360.00 E7200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X360 Y360 Z350 S0 ; set axis maxima
M206 Y-10 X-34; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X25 Y0 Z0.65 ; set Z probe trigger value, offset and trigger height
M557 X15:300 Y35:300 S40 ; define mesh grid; Heaters
M950 S0 C"exp.heater7" ;
M307 H0 ; ısıtıcı 0 için proses parametrelerini rapor edin
M307 H1 R2.186 K0.17:0.11 D5.67 S1.00 V24.0 ; disable bang-bang mode for the bed heater and set PWM limit
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"fan0" Q15 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"fan1" Q15 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F-1 ; define tool 0
M575 P1 S1 B57600 ; enable support for PanelDueM591 P2 C"e0_stop" D0 S1 ; filament monitor connected to E0_stop
M501
@Blackpart Has this setup been working for some time or is it a new build? Either way that error usually indicates either a problem with the wiring to the sensor or a problem with the sensor itself.
@gloomyandy
Hello, the firmware was upgraded from 3.1.1 to 3.4.6, then this error was received. The wiring part was not touched -
@Blackpart almost certainly it is caused by a bad connection and it is coincidence that it started when you did a firmware upgrade.
BTW you have two M307 H1 commands in config.g. The first one should be moved to be after the M950 H1 command that creates the corresponding heater, and the second one removed.
