Controlling a DFROBOT DFR0017 realay module with PSON
I'm trying to hook up and use some "DFR0017" relay modules to turn on/off the 24v psu on my machine.
The machine runs a Duet 3 Mini (wifi), and i'm trying to use the
pson
pin to controll the relay modules.As of now I've wired up the "control side" connectors on the relay module with
VCC
to 5+ from the 5v PSU,Ground
to the machines ground distro andSignal
to the duetspson
pin.I've also put
M80 C"pson"
&M80
in config.g, but the relay won't turn on. So i suspect theSignal
pin on the relay module wants a positve signal.Will it be "safe" to swap over both
Signal
&VCC
to the same 5+ and runGround
to the Duetspson
pin? Or is that frowned apon?
EDIT:
I went ahead and did like i said above, and it worked like I thought/hoped.
It made me aware of some pitfalls/flaws in the way i've wired it up though. But i'll make a dedicated post touching on that subject
