Motor phase may be disconnected
Have a printer that has been running and working just fine, during a print in the night a few nights ago it just stopped printing with one of these errors. Turned printer off and printed a smaller part, that part came out just fine. When I went to print another part this is the error I receive when I home the machine now. Have reseated all the motors and tried a replacement motor in all the spots to see if that is the root cause with no luck.
Firmware Version: 2.05.1 (2020-02-09b1)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6If by chance I need to switch board/firmware out. Are the settings from this version transferable to another/newer board or is there much tweaking?
Note this screenshot just shows 0 and 1 but driver 2 also throws a code, and the error I was getting also shows 0 1 3 if that means anything.
Are these errors happening on motors with fixed wiring or wiring that moves with the print head?
The error message is saying that there may be disconnected wiring, perhaps even intermittent. So that would be the first thing to check.
It's unlikely that a firmware update would improve the situation if it's been working fine as it is.
Has the configuration changed recently?
