3.5.0-rc.1 has the working directory definition changed?
I've recompiled DuetLapse3 against 3.5.0-rc.1 (no other changes).
This is the output from journalctl
Sep 19 11:02:49 srsender DuetPluginService[219029]: System.ComponentModel.Win32Exception (2): An error occurred trying to start process '/opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py' with working directory '/opt/dsf/plugins/DuetLapse3/dsf'. No such file or directory Sep 19 11:02:49 srsender DuetControlServer[219006]: DuetAPI.InternalServerException: An error occurred trying to start process '/opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py' with working directory '/opt/dsf/plugins/DuetLapse3/dsf'. No such file or directory Sep 19 11:02:49 srsender DuetWebServer[730]: DuetWebServer.Controllers.MachineController[0] [StartPlugin] Failed to start plugin DuetAPI.InternalServerException: An error occurred trying to start process '/opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py' with working directory '/opt/dsf/plugins/DuetLapse3/dsf'. No such file or directory at DuetAPIClient.BaseConnection.PerformCommand(BaseCommand command, CancellationToken cancellationToken) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 156 at DuetWebServer.Controllers.MachineController.StartPlugin() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetWebServer/Controllers/MachineController.cs:line 1105 The permissions look ok
pi@srsender:/opt/dsf/plugins/DuetLapse3 $ ls -l total 8 drwxrwxr-x 2 dsf dsf 4096 Sep 19 08:55 dsf drwxrwxr-x 4 dsf dsf 4096 Sep 19 08:55 dwc pi@srsender:/opt/dsf/plugins/DuetLapse3 $ ls -l ./dsf total 152 -rwxrwx--- 1 dsf dsf 152930 Sep 19 08:55 DuetLapse3.py pi@srsender:/opt/dsf/plugins/DuetLapse3 $ I presume (???) that the correct version of the dev environment for rc.1 is here
https://github.com/Duet3D/DuetWebControl/tree/v3.5-dev
If I run the plugin code manually - it works as expected:
sudo python3 /opt/dsf/plugins/DuetLapse3/dsf/DuetLapse3.py -file /opt/dsf/sd/sys/DuetLapse3/DuetLapse3.config My plugin.json is below. The only change from 3.5.0-beta.4 (which worked fine) is the version requirements
{ "id": "DuetLapse3", "name": "DuetLapse3", "author": "Stuartofmt", "version": "5.3.2", "license": "GPL-2.0-or-later", "homepage": "https://github.com/stuartofmt/DuetLapse3", "dwcVersion": "3.5.0-rc.1", "sbcRequired": true, "sbcDsfVersion": "3.5.0-rc.1", "sbcExecutable": "DuetLapse3.py", "sbcExecutableArguments": "-file /opt/dsf/sd/sys/DuetLapse3/DuetLapse3.config", "sbcOutputRedirected": false, "sbcPermissions": ["commandExecution", "objectModelReadWrite", "networkAccess", "webcamAccess", "readSystem", "writeSystem", "fileSystemAccess","launchProcesses", "managePlugins"], "sbcPythonDependencies": ["requests", "psutil"] } -
@stuartofmt Can you please share the full plugin ZIP bundle so I can give it a try?
Here you go. It installs without error but throws the above as soon as Start is pressed.
I misreported. Something was changed!
This is the first build of the plugin I am attempting on Bullseye 64K with DSF/DWC installed using the usual instructions. The installation was error free and I have full control over my printer using DWC. ALso, as reported above, I can successfully invoke the plugin code from the command line.
About a year ago or so ago, I had the same error and ended up "downgrading" to the official Duet3d Buster release to get it working.
Is it possible that there is something between the two versions of Debian that is causing the issue? Is there an official build Duet3d Bullseye version (I could not find one)?
P.S. I also tried with
"sbcExecutableArguments": "-file ../DuetLapse3/DuetLapse3.config",
Same error. -
@stuartofmt Linux is quite strict when it comes to mode strings (first line in your script). If you encode Python scripts using CRLF line endings, Linux will attempt to start
python3\r
and notpython3
, so try to change the line ending to LF only. That should fix it. -
Thanks! I did not even look at line endings because its been fine up until this last round. Its the strangest thing - I have Visual Studio Code set to default to unix EOL . For some unknown reason, these files were reset to CRLF.
Possibly during a file transfer (something I need to look into).
Again - THANKS!
@stuartofmt Check your git settings, maybe that changed it on commit.
