    POLAR PRINTER
    • xXJRUSHMANXxundefined
      xXJRUSHMANXx
      Good morning everybody. I'm making a polar printer, where X is angular mov and Y,Z are lineal. Is not the turntable, its "turnbody" machine.
      Looking for a Z=0 plane, we have some type of a "donut" print zone. (Ej: Dint=10cm; Dext=40cm;) I think that the coordinates origin of cartesian / polar sistem are the center of the machine.
      In config I have M669 K7 .... but I dont khnow to make correct configuration becouse I have different design.
        dc42 administrators @xXJRUSHMANXx
        @xXJRUSHMANXx have you read https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_Polar ?
        xXJRUSHMANXxundefined 1 Reply Last reply Reply Quote 1
          xXJRUSHMANXx @dc42
          @dc42, yes I did! I'm sorry for my ignorance.
          I have some accurate questions about it:
          1. How you can see, my Rmax=400mm and Rmin=100mm from the center of rotation. But at 100mm from this center, I have "X_end" => H100.
            So, It's correct M669 K7 R100:400 H100?
            Or It should to be M669 K7 R0:300 H100?
          2. If I have TB6600 drivers configurated by micro-stepping, I understand that I no need Snnn and Tnnn (segmentation), true?
          3. In a sample, you don't have M208 for Z axis. I think that its necesary here.
          4. About the interface, I don't khnow softwares that can manipulate "donut_print_zone", should I send Gcodes manually (in cartesian coordinates)?
          I hope I'm not disturbing you so much... I really need to get it for my university project. I've been with this for a long unsuccessfully.
          When I finish it, I would like to reward you for your help!!!!
            @xXJRUSHMANXx said in POLAR PRINTER:
            That's correct if your radial homing switch triggers at radius 100mm.
            Segmentation is always used when polar kinematics is selected. You can omit the S and T parameters to use the default, or choose them yourself.
            Yes, you should use M208 to configure the Z axis limits.
            For normal prints that don't have a large hole in the centre on all layers, you will need to offset the print so that e.g. all X coordinates are at least +100mm. You may be able to configure this in your slicer. Alternatively, use G10 with parameter L2 to configure a workplace offset, and put this in your slicer start GCode.
            • oliofundefined oliof referenced this topic
