    Duet bed not receiving power
    313
    • ageisundefined
      ageis
      So i turned on the bed heater using the web interface. The led next to the terminals for the bed turns on. However when measure across the terminals I don't get the 13v I get at vin. I have checked vin and it's 13 volts no minor( 12.9 - 13.2) fluctuations as suggested on the readout on the web interface.
      I have just discovered the bed appears to load the rail so much it reports 0 volts. How is that possible, would it not affect the vin voltage as well?
      Without the bed connected it reports 13v as expected. I have used ferrules on the cables like prusa have done on vin. I have also used ring terminals on the vin terminal on the bed itself. They're are tight. By ring terminals I mean The ones electricians use on a earth clamp.
      I have measured the cable cross sectional area to be 3.3mm. The cable is only short maybe 17 inches. Not very accurate because the cables aren't straight. According to my multimeter, the heater is 0.9 ohms.
      So do I need a bigger psu? If so how many watts would you think I need? It's a standard I3 printer just just one hot end and usual steppers and bed
      jens55undefined 1 Reply Last reply Reply Quote 0
      • jens55undefined
        jens55 @ageis
        @ageis, is the Duet crashing when you turn the bed on? If it is then you likely have insufficient power produced by the power supply. If the Duet is not crashing then the next suspect would be the fuse that is on the Duet that protects the bed circuit. If that fuse is OK then it could be the FET that does the switching.
        ageisundefined 1 Reply Last reply Reply Quote 0
        • ageisundefined
          ageis @jens55
          @jens55 omg it might be the fet. The fuse next to the bed connector is fine.
          If that's the right fuse. It's the only fuse I can see that could be a bed fuse. The other two are too small.
          So does anyone know of a place in Manchester that does this sort of board level repair? I can't do smd work. The last time I tried, it was a complete write off. We all know the duet isn't a cheap board. So I think it'll be worth to repair it. As long as the repair shop doesn't ask for silly prices to replace a 2 quid fet. It should be straight forward for them to replace. There's schematics too so its not like they need to spend time finding the fet.
          It's probably damage from the short circuit accident I had a few months ago. It appeared to still work afterward though. It's given up.
          • jens55undefined
            jens55 @ageis
            I have found (the hard way) that shorting FET outputs is a pretty reliable way to kill the FET 😞 I am surprised that it still appeared to work afterwards but I suppose it could be a case of it getting damaged and eventually failed completely.
            The FET is much faster than the fuse so the fuse will not protect the FET.
            • ageisundefined
              ageis @jens55
              @jens55 Thats sad. Am just curious would a poly fuse be any better?
              • jens55undefined
                jens55
                Just as an FYI - it might be cheaper to just use a different output and run it through an external SSR. Of course a standard relay would work as well (reduced lifetime?) but depending on which output you use, you might need a flyback diode.
                • ageisundefined
                  ageis @jens55
                  @jens55 how would that tie in with the control logic? The firmware needs to know it's not on that output anymore?
                  • jens55undefined
                    jens55 @ageis
                    @ageis yes, you will need to adjust your config.g file accordingly. Post your config.g file and hopefully somebody better at interpreting things will tell you how config.g needs to be tweaked.
                    Please provide info of the hardware and firmware you are using as that will affect things. Please also post what I/O ports are available. For example, if you have a single hot end, you are likely using E0Heat to power that hot end and you might have E1Heat available for the bed heater. Another choice would be a fan output if you have one that is open.
                    These comments are mostly about a Duet2wifi as that is what I last played with. If you have a Duet3 6HC you would have different ports and different ways of configuring things.
                    • ageisundefined
                      ageis
                      ; Configuration file for Duet WiFi (firmware version 3.3)
                      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun Jul 23 2023 20:00:34 GMT+0100 (British Summer Time)
                      G90                                            ; send absolute coordinates...
                      M83                                            ; ...but relative extruder moves
                      M550 P"prusa"                                  ; set printer name
                      M552 P0.0.0.0 S1                               ; enable network and acquire dynamic address via DHCP
                      M586 P0 S1                                     ; enable HTTP
                      M586 P1 S0                                     ; disable FTP
                      M586 P2 S0                                     ; disable Telnet
                      M569 P0 S1                                     ; physical drive 0 goes forwards
                      M569 P1 S1                                     ; physical drive 1 goes forwards
                      M569 P2 S1                                     ; physical drive 2 goes forwards
                      M569 P3 S1                                     ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                               ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                      M92 X100.00 Y100.00 Z400.00 E161.3             ; set steps per mm
                      M566 X900.00 Y900.00 Z12.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
                      M201 X500.00 Y20.00 Z400.00 E250.00            ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                        ; Set idle timeout
                      M208 X0 Y0 Z0 S1                               ; set axis minima
                      M208 X250 Y190 Z210 S0                         ; set axis maxima
                      M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                      M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
                      M558 P1 C"zprobe.in+zprobe.mod" H10 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                      G31 P500 X230 Y9 Z5.35                         ; set Z probe trigger value, offset and trigger height
                      M557 X15:235 Y15:190 S20                       ; define mesh grid
                      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0                               ; define tool 0
                      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                      Be grateful if someone can tell how to reconfigure the heated bed control pin to a different pin.
                        Phaedrux Moderator @ageis
                        @ageis said in Duet bed not receiving power:
                        Which pin do you want to use instead?
                        Find the pin you want to use and look up it's name here: https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pin-names
                        Then replace "bedheat" with that pin name.
