    unable to extrude despite at temp
    Duet Web Control
    extrusion
    • ageisundefined
      ageis
      So I have the hotend at 215 and the bed at 65.
      But the extrusion controls are disabled. Usually in the old firmware I can extrude around 180.
      Here is my config: I dont have any filaments defined in the filaments section
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun Jul 23 2023 20:00:34 GMT+0100 (British Summer Time)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"prusa"                                  ; set printer name
      M552 P0.0.0.0 S1                               ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E161.3             ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y20.00 Z400.00 E250.00            ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X250 Y190 Z210 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in+zprobe.mod" H10 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X230 Y9 Z4.8                         ; set Z probe trigger value, offset and trigger height
      M557 X15:235 Y15:190 S20                       ; define mesh grid
      M950 H0 C"bedheat" T0                        ; create bed heater output on bedheat and map it to sensor 0
      ;M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H0 R0.268 K0.283:0.000 D13.25 E1.35 S1.00 B0
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @ageis
        @ageis activate the tool by sending T0
        best to add T0 to the end of your config
        ageisundefined 1 Reply Last reply Reply Quote 0
        • deckingmanundefined
          deckingman @ageis
          @ageis Try what @jay_s_uk said first, but from your screen shot, it looks like the tool was indeed active. If that is the case, then the command which controls extrusion temperature is M302. According to the docs, it should default to 160 for extrusion and 90 for retraction using the S and R values respectively. Try sending M302 without any parameters to see what gets reported back. If it's something other than 160/90 then look for an M302 elsewhere, for example config_override.g or perhaps in the slicer start code or a macro that you might have run prior to attempting to extrude.
          • ageisundefined
            ageis @jay_s_uk
            @jay_s_uk
            Thanks Jay it seems to be working now.
            Maybe it needs to be fixed in the reprap config tool. I am very sure I used it because I upgraded from a very old version of the firmware to the latest. I remember generating a new set of config files based on an older config.
            droftartsundefined 1 Reply Last reply Reply Quote 1
              droftarts administrators @ageis
              @ageis There's an option in the config tool to select the first tool on startup, which is not on by default. It adds T0 at the end of config.g.
              Also, the commissioning guide explains you need to enable the tool to extrude: https://docs.duet3d.com/en/How_to_guides/Commissioning#h-6-check-heater-functionality
              When the tool is active, it will be highlighted blue in DWC. The heater can be active, even if the tool is not active.
              • ageisundefined
                ageis @droftarts
                @droftarts
                Ah good to know. I wasn't aware of that.
