Having Issues Using Telnet Connection
In my config file I have this command which is supposed to enable Telnet:
M586 S1 P2 T0 R2323
This command does not send the message to a server listening on port 2323:
M118 P4 S"TEST"
Is the Duet acting like a client or a server?
If a client what do I need to do to get the above to work?
Thanks much.
@fcwilt RRF is a telnet server, not a client.
@gloomyandy said in Having Issues Using Telnet Connection:
Well that explains the problem.
Thanks.
