    Y axis Hesitates on Homeall and Homey [SOLVED]
    • Silroccoundefined
      Silrocco
      Hi all.
      I decommissioned a delta and repurposed the Mini 5 on an old TAZ 4, which ran solid with the Maestro board, but I thought I'd give it an upgrade. I feel I'm 99% there, but the y axis has me frustrated.
      When I command a "homeall", I notice an odd behavior with the y axis, it starts at the same time as x, but then the y stalls, then tries to move again with hesitation, only after the x has finished it's homing procedure. The y restarts slowly, then accelerates hitting the minimum limit hard (I e-stop it here).
      I have tried several things, like reversing the direction of y and changing the endstop to high end, no success. Changed the drive assignment physically and in the config to match, same results. M119, show that the endstops are getting triggered when I actuate them by hand. Nonetheless, x and z axis home fine.
      Than you!
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat Sep 30 2023 23:42:55 GMT-0700 (Pacific Daylight Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Old Man TAZ"                          ; set printer name
      M552 P0.0.0.0 S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.0 S0                                 ; physical drive 0.1 goes backwards (X Axis)
      M569 P0.1 S0                                 ; physical drive 0.2 goes forwards  (Y Axis)
      M569 P0.2 S0                                 ; physical drive 0.3 goes backwards (Z1 Axis)
      M569 P0.3 S0                                 ; physical drive 0.3 goes backwards (Z2 Axis)
      M569 P0.4 S0								 ; physical drive 0.0 goes backwards (Extruder)
      ; Movements
      M584 X0.0 Y0.1 Z2:3 E0.4                 		; set drive mapping
      M350 X16 Y16 Z16 E16 I1                     	; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z1200.00 		        	; set steps per mm
      M92 E420.00										; set extruder E0 steps/mm
      M566 X1000.00 Y1000.00 Z60.00 E120.00        	; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00      	; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00          	; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I60                 	; set motor currents (mA) and motor idle factor in per cent
      M84 S60                                      	; Set idle timeout
      M671 X20:140 Y145:145 S2.0 P0.5				 ; lead-screws at left and right of X axis, X270:55:270:55 Y235:235:15:15
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X295 Y295 Z250 S0                       ; set axis maxima
      M574 X1 S1 P"!io6.in"                        ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io6.in
      M574 Y1 S1 P"!io5.in"                        ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io5.in
      M574 Z1 S2
      M950 S0 C"io3.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"io3.in" H5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
      G31 P10 X0 Y-45 Z1.675                       ; set Z probe trigger value, offset and trigger height
      M557 X20:275 Y30:240 S40                     ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 		; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                           		; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                             		; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      		; map heated bed to heater 0
      M143 H0 S120                                 		; set temperature limit for heater 0 to 120C
      M307 H0 R0.130 K0.150:0.000 D10.00 E1.35 S1.00 B1 	; PID Tuning
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 			; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                           			; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                             			; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                 			; set temperature limit for heater 1 to 280C
      M307 H1 R2.195 K0.334:0.276 D5.26 E1.35 S1.00 B0 V25.0 	; PID Tuning
      M950 F0 C"vfd" Q500                          ; create fan 0 on pin vfd and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out5" Q500                         ; create fan 1 on pin out5 and set its frequency
      M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"E3D_E0" D0 H1 F0                   ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.6 (2023-07-21 14:09:13) running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: Z4XQ1-1096U-D65J0-40KMA-2T03Z-RQ92N
      Used output buffers: 1 of 40 (26 max)
      Static ram: 103712
      Dynamic ram: 104764 of which 12 recycled
      Never used RAM 33104, free system stack 144 words
      Tasks: NETWORK(ready,27.2%,174) ETHERNET(notifyWait,0.2%,560) HEAT(notifyWait,0.0%,342) Move(notifyWait,0.0%,290) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,342) TMC(notifyWait,0.7%,72) MAIN(running,71.0%,423) IDLE(ready,0.0%,30) AIN(delaying,0.8%,263), total 100.0%
      Owned mutexes:
      Last reset 01:08:54 ago, cause: software
      Last software reset at 2023-10-01 11:57, reason: User, GCodes spinning, available RAM 33224, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 4134730, completed 4134729, timed out 0, errs 0
      Step timer max interval 752
      MCU temperature: min 36.4, current 36.6, max 36.9
      Supply voltage: min 24.5, current 24.5, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 4, read errors 0, write errors 0, ifcnt 98, reads 549, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 110, reads 549, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 2, read errors 0, write errors 0, ifcnt 110, reads 548, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 2, read errors 0, write errors 0, ifcnt 110, reads 549, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 89, reads 549, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2023-10-01 13:06:40
      Slowest loop: 1.79ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.4ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 5, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 8, completed 8, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 94, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 52/0/0
      Tx timeouts 0,0,52,0,0,42 last cancelled message type 4514 dest 127
      === Network ===
      Slowest loop: 3.52ms; fastest: 0.04ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      State: active
      Error counts: 0 0 0 0 0 0
      Socket states: 5 2 2 2 2 0 0 0
      • gloomyandyundefined
        gloomyandy @Silrocco
        @Silrocco I can't see any problems with the config, it is probably worth running M98 p"config.g" to check it for any errors. Could you also post your homing files?
        Silroccoundefined 1 Reply Last reply Reply Quote 0
        • Silroccoundefined
          Silrocco @gloomyandy
          @gloomyandy Hi.
          I just solved the issue. I noticed in Object Model that the Y endstop was not showing "highEnd" and "type" it was for the X, but it was triggering, but not home as mentioned. So I switched over to another io, io5 to io2 and that solved it!
          ![Fixed]8be09707-9ca7-45f9-9a41-ffe26ecc5f8d-image.png image url)
          One more thing, I switched over to Normally Closed.
