    Can't connect to Wifi - SPI Timeout
    Firmware installation
    • TimsWorkshopundefined
      TimsWorkshop
      Hi all!
      So my SD card slot stopped working out of nowhere and I am in the process of putting in a replacement board.
      I've upgraded the firmware from 3.1.1 -> 3.3 -> 3.4.6 and in all of these instances, I cannot get my WiFi access to work as every time I try to set my network details with M587, I get errors stating SPI Timout.
      Here's my M587 command
      >>> M587 S"Skynet" P"******"
      SENDING:M587 S"SKYNET" P"*******"
      Error: M587: Failed to add SSID to remembered list: SPI timeout
      [ERROR] Error: M587: Failed to add SSID to remembered list: SPI timeout
      Once this happens, I did try turning the WiFi module off and back on, but got the same result.
      I've tried re-installing the firmware, but still the same SPI error.
      I read on an old Git issue that sometimes M587 will not work the first time, but the second time it always does, and so I tried that, but after the first failed M587, the WiFi module turns off:
      >>> M552 S0
      SENDING:M552 S0
      Error: WiFi module reported: no known networks found
      [ERROR] Error: WiFi module reported: no known networks found
      WiFi module is idle
      >>> M552 S1
      SENDING:M552 S1
      Error: M587: Failed to add SSID to remembered list: WiFi module is disabled
      [ERROR] Error: M587: Failed to add SSID to remembered list: WiFi module is disabled
      I do see that 3.4.6 does not have a Duet2_SDIAP32_WiFiEth.bin, but 3.4.5 does and this is the one I used... Unsure if that's an issue?
      And below is the output of M122, I do see that my WiFi version is 1.02 - is that the most recent?
      Output of M122
      >>> M122
      SENDING:M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S8-6JKD4-3SJ6T-9A46J
      Used output buffers: 1 of 26 (3 max)
      Static ram: 23896
      Dynamic ram: 75924 of which 0 recycled
      Never used RAM 9404, free system stack 193 words
      Tasks: NETWORK(ready,7.5%,336) HEAT(notifyWait,0.0%,353) Move(notifyWait,0.0%,363) MAIN(running,90.8%,456) IDLE(ready,1.7%,30), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:00:54 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      [ERROR] Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 27.9, current 30.4, max 30.7
      Supply voltage: min 1.4, current 1.8, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Heap OK, handles allocated/used 99/26, heap memory allocated/used/recyclable 2048/374/0, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min n/a
      Driver 1: ok, SG min n/a
      Driver 2: ok, SG min n/a
      Driver 3: ok, SG min n/a
      Driver 4: ok, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Cache data hit count 2329443531
      Slowest loop: 4.28ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === Network ===
      Slowest loop: 1.34ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 0 of 8
      = WiFi =
      Interface state: active
      Module is idle
      WiFi firmware version 1.23
      WiFi MAC address e0:98:06:23:00:47
      WiFi Vcc 3.47, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27448
      Clock register ffffffff
      Keen to see if I missed a step or updated the firmware in the incorrect order and if someone knows how I can get out of this SPI Timeout error?
      Thanks for reading!
      Tim
      Ender 5 Plus - E3D Hemera Hotend - Duet 2 Wifi
        jay_s_uk @TimsWorkshop
        @TimsWorkshop your WiFi firmware is 1.23 with the latest being 1.27. So you could do with updating that.
        When sending your M587 command, send M552 S0 before hand.
        TimsWorkshopundefined 1 Reply Last reply Reply Quote 0
          TimsWorkshop @jay_s_uk
          @jay_s_uk - thanks mate. I did some backwards looking through previous releases, and found the most recent wifi version update, so I'm now on 1.27. Good shout.
          I've gone back and did the following, which shows my network, but with an IP of 0.0.0.0
          >>> M552 S0
          SENDING:M552 S0
          WiFi module is idle
          >>> M587
          SENDING:M587
          Remembered networks:
          TNCAPF2FD81 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
          SKYNET IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
          So seeing this, I then decided to clear the list with M588 S"*".
          I then M552 S0 and then re-added my network with M587.... but I still can't connect.
          Very weird behaviour
            TimsWorkshop @TimsWorkshop
            Not sure if worth mentioning, but I have it set as client mode.
            I did try with AP mode, but same problem persisted.
              @TimsWorkshop what type of network is it? The ESPs are 2.4ghz only
                @jay_s_uk It's a 2.4
                  Can you send these commands and report the responses?
                  M552 S-1
                  M552 S0
                  M552 S1
                  M997 S1
                  M588 S"*"
                  And then your M587 command to add your SSID.
                  Another thing to test is to try in AP mode to see if the module is working correctly there or same issues.
