    Web Interface Freeze After Auto-Calibration
    Firmware installation
    894
    • wwmotorsportsundefined
      wwmotorsports
      Hi all!
      I just finished re-building my Rostock with a new Duet Wifi, 0.9° steppers, and a 24V power supply.
      Everything is working perfectly and the improvement in print quality over the stock 1.8° steppers that came stock with the Rostock is incredible, especially when printing at small layer heights.
      The only issue I am having is that the web interface freezes after the auto-calibration completes and tries to pull up the height map. The same thing happens if I try to load the height map and view it after reloading the web interface.
      Any ideas as to what may be causing this issue?
      Thanks ahead of time!
      • chrishammundefined
        chrishamm administrators
        What browser and firmware versions are you using?
        Duet software engineer
        • Dougal1957undefined
          Dougal1957
          that is very similar to what I am getting but only on mesh bed see my post on this running latest RC2 versions
          • Gosuundefined
            Gosu
            I have the same Issue everything is ok but when i Calibrate i cannot connect to my Printer but im able to print though i cannot see the status nor reconnect to the printer.
            • Gosuundefined
              Gosu
              sorry for hijacking this happens with Chrome Firefox and even with Edge
              Runningits FW RC2
              Wifi Beta10 i believe
              and RC3 Webclient
                wwmotorsports
                Thanks for all of the responses and sorry for the delayed response!
                I am using firmware and wifi version 1.19 and web interface 1.15a and using Google Chrome, but the same errors present in Internet Explorer as well.
                It appears that I was having an occasional probing error that was causing some of the errors, and I have fixed that issue. At this point, I can run the auto-calibration and the web interface will not freeze and the G-code console will report the adjustment, but when I try to load the heightmap the web interface will still freeze.
                Thoughts?
                • whosrdaddyundefined
                  whosrdaddy
                  your web interface (DWC) version is old.
                  Upgrade to latest firmware/DWC version (1.20)
                    wwmotorsports
                    Thanks, that did the trick!
