    Autocompensation (G32)problem -map shows more points then defin(fixed)
    • bschubertdoundefined
      bschubertdo
      i recognised that my leveling was off and run it manually to see whats up.
      under the map it says 4 probed points but on the image i see 6 points
      https://imgur.com/a/4ElFW
      i never added those mid points and cant get rid of them. cant get it to level again
      Before you ask why im not using mesh level - got problems with my pei sheet and consistancy on dc42 ir probe
      my bed is really flat and the 4 corner method worked perfectly for me.
      is there any way i can delete those
      bed.g
      M561
      G30 P0 X30 Y22 H0 Z-99999
      G30 P1 X30 Y295 H0 Z-99999
      G30 P2 X311 Y295 H0 Z-99999
      G30 P3 X311 Y22 H0 Z-99999 S
      Firmware Electronics: Duet WiFi 1.0
      Firmware Version: 1.20beta7 (2017-11-11)
      WiFi Server Version: 1.20b8
      Web Interface Version: 1.19.3
        Do you have a heightmap.csv file left over from when you tried mesh bed compensation? If so then DWC may be picking that up instead, so delete it.
          bschubertdo
          Thanks for your fast reply - i already deleted that file
          Seems like i have to reinstall the firmware
            Let me know if it still happens using firmware 1.20RC1, if so then I'll see if I can reproduce it.
              bschubertdo
              Got it fixed
              • Updated/Changed to 1.20RC1 - same problem
              I saved my config.g bed.g home, pause and resume files and put completly fresh files on the sd card
              and still same problem. i tripple checked all files for spelling errors etc an wrote files from scratch but nothing helped
              after that a friend said why dont you try mesh again just to see if that one works
              i reenabled mesh in config.g (M557 X30:311 Y22:295 S20) ran it once and the problem was gone
