    Temperatures not displaying on PanelDue
    PanelDue
    • JeanCundefined
      JeanC
      Hello, I'm working on a Duet 3 XD with PanelDue 7i 3.5.0
      On DWC, I can display temperatures on the tools board but how can I show them on the PanelDue. Is-there commands to add ?
      In the config file, I define the temp sensors like this :
      M308 S1 P"spi.cs1"Y"thermocouple-max31856" K"K"
      Can someone help me ?
        Can you share your full config.g?
        The PanelDue is fairly limited in what it can display. It's expecting tools and bed heaters mainly.
        JeanCundefined 1 Reply Last reply Reply Quote 0
        • JeanCundefined
          JeanC @Phaedrux
          @Phaedrux Here is my config file :
          ;config.g
          M552 S1 P0.0.0.0 ;enable DHCP network
          M575 P1 B57600 S1 ;set communication parameters with the PanelDue : 57600 bauds
          ;configure termocouples and ssr pins
          M308 S1 P"spi.cs1"Y"thermocouple-max31856" K"K" ;create temp sensor 1
          M308 S2 P"spi.cs2"Y"thermocouple-max31856" K"K"
          M308 S3 P"spi.cs3"Y"thermocouple-max31856" K"K"
          ;M308 S4 P"spi.cs4"Y"thermocouple-max31856" K"K"
          M950 P0 C"out0" ;create output for ssr 1
          M950 P1 C"out1"
          M950 P2 C"out2"
          M564 H0 ;allow movement of axes that have not been homed
            Is that your full config? You have sensors defined, but the paneldue is expecting heaters.
            What is it exactly that you're trying to do?
            • JeanCundefined
              JeanC @Phaedrux
              Hello @Phaedrux, I'm not trying to control a printer, I make a machine with a stepper motor, 3 thermocouples and 3 ssr that control heating lamps.
              Since the last time, I changed my config with the config tool in order to make it more complete but it does the same thing.
              ; Configuration file for Duet 3 MB 6XD (firmware version 3.3)
              ;general preferences
              G90                                         ; send absolute coordinates
              M550 P"proj"                             ; set name
              ;network and communications
              M552 S1 P0.0.0.0                            ; enable DHCP network
              M586 P0 S1                                  ; enable HTTP
              M586 P1 S0                                  ; disable FTP
              M586 P2 S0                                  ; disable Telnet
              M575 P1 B57600 S1                           ; set communication parameters with the PanelDue : 57600 bauds
              ;thermocouples
              M308 S1 P"spi.cs1" Y"thermocouple-max31856" K"K" A"TC1"; create temp sensor 1
              M308 S2 P"spi.cs2" Y"thermocouple-max31856" K"K" A"TC2"
              M308 S3 P"spi.cs3" Y"thermocouple-max31856" K"K" A"TC3"
              ;ssr
              M950 P0 C"out0"                             ; create output for ssr 1
              M950 P1 C"out1"
              M950 P2 C"out2"
              ;drives
              M569 P0 S1                                  ; physical drive 0.0 goes forwards
              M584 X0                                     ; set drive mapping
              M350 X16                                    ; set microstepping mode for x axis
              M92 X80                                     ; set steps per mm
              M566 X900                                   ; set maximum instantaneous speed changes (mm/min)
              M203 X1000                                  ; set maximum speeds (mm/min)
              M201 X500                                   ; set accelerations (mm/s^2)
              M906 X800 I30                               ; set motor currents (mA) and motor idle factor in per cent
              M84 S5                                      ; set idle timeout
              M564 H0                                     ; allow movement of axes that have not been homed
              M501
              And as long as I'm in conversation, do you know how to control the motor to make it turn a certain number of degrees (it controls a turntable).
              Thank you for replying 🤝
