    Possible to "override" fan speed from DWC?
    Duet Web Control wishlist
    • janjohundefined
      janjoh
      If I recell correctly there used to be a way to "Pin" a fan speed in older DWC. But, I have not seen that lately. And looking in the documentation for DWC I see not mention of it.
      Is it possible to acheive the same thing? I guess both "pinning" and "ofsetting" fan speed could be of interest.
      • Phaedruxundefined Phaedrux moved this topic from Duet Web Control
        droftarts administrators @janjoh
        @janjoh Do you mean the 'pin' icon in the Fan Control section of the Print Status in the old DWC v1 interface?
        This just changes if the fan shows all the time or not. DWC v2 and v3 have the same thing, it's just in a drop down menu when you click on 'Change visibility':
        For 'offsetting', you can control the minimum and maximum PWM value by setting the L and X parameters in M106
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m106-fan-on
        The L parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
        The X parameter defines the maximum PWM value that is usable with this fan. The requested PWM value (S parameter) is scaled to be between 0 and X parameter value, and rounded up to the minimum if defined (L parameter). e.g. if X128 is set, S255 will set PWM to 128; S128 will set PWM to 64.
        janjohundefined 1 Reply Last reply Reply Quote 0
        • janjohundefined
          janjoh @droftarts
          @droftarts Aaah... I thought it was to "lock" the fan speed. Never used it back then. And now I found a use for it when i kinda goofed my slice.
            Phaedrux Moderator @janjoh
            @janjoh said in Possible to "override" fan speed from DWC?:
            I'm quite sure it was for doing that too.
