    Mis interpreted g1 x0 y0 command after homing scara arm
    275
    • gnmrc_undefined
      gnmrc_
      Hi, I’ trying to home a 5 bar scara, while the 2 rotational arms home correctly, I can’t figure out a way to home z because after homing the 2 arm and sending :
      G1 X0 Y0 F300 S2
      the arm does not move to the correct zero position(the center of the bed) it completely overshoots it moving far from the teoretical position.
      If instead I manually home the machine with G92 and than send the code to move to the zero position the arm works correctly.
      Me and @fcwilt are 3 days that are trying to solve the problem, but we haven’t figure it out yet.
      Thanks in advance for the help.
      Gianmarco
      infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @gnmrc_
        @gnmrc_ said in Mis interpreted g1 x0 y0 command after homing scara arm:
        That’s no good reason to start a new thread. What’s worse, all context is lost, you don’t even provide a link to the initial thread. Oh, and don’t blame @fcwilt: I’ve followed the thread, and although I’m not a scara expert, I learnt that the 0/0 position is an inherent problem of that geometry. While @fcwilt tries to focus on this, you run circles around his good advice, experimenting with all kind of other stuff. Please stick with a single thread on a single topic.
        gnmrc_undefined 1 Reply Last reply Reply Quote 0
        • gnmrc_undefined
          gnmrc_ @infiniteloop
          @infiniteloop I’m not blaming anyone btw I am really thankful for ghe help that is giving me, I thought it was better to make another thread because we were talking about another topic.
          For the link to the other thread I forgot to put it here so thank you.
          And finally I’m not running cycles around it’s advices I’m trying to understand and apply what he says.
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
            @gnmrc_ Just noticed you continue the initial thread 👍
            Hint: Search this forum for "5 bar scara" in order to find relevant contributors, then, address them in your thread (like this: @gnmrc_ - any ideas on this? ) to ask them for support.
            • gnmrc_undefined
              This post is deleted!
              • fcwiltundefined
                fcwilt @gnmrc_
                @gnmrc_
                Hi again,
                What are we doing over here?
                Now we cannot scroll back through the previous posts to check things.
                Oh well, we will get it sorted.
                Referring back to M564
                Have you tried executing...
                M564 H0 S0	                ; H0 = ignore axis homed state, S0 = respect axes limits
                ...and then carefully jogged X and Y to verify that various X and Y values are corresponding to the physical position you think they should?
                Maybe your M669 is not quite right.
                • gnmrc_undefined
                  gnmrc_ @fcwilt
                  @fcwilt no you are right lets keep all the information on that thread it’s simpler for all of us
                    droftarts administrators @gnmrc_
                    @gnmrc_ I'm locking this thread so you can keep discussion on the original thread: https://forum.duet3d.com/topic/33846/problem-configuring-z-probe-using-fsr-switch
                    Maybe think about changing the title of that post (hint: edit your first post in the thread) to include that the problem is related to Scara arm.
                    • droftartsundefined droftarts locked this topic
