    Error Code 1
    • djthumaundefined
      djthuma
      Hello, I have a custom built machine for work that is running off a duet 2 ethernet and duex expansion. Nema 23 motors. I can send the config file if needed.
      I am getting a random error code 1 in the middle of prints.
      I am using cura as a slicer. Please let me know what this error code is? Advice?
      Thank you
        dc42 administrators @djthuma
        @djthuma that error code means that the hardware was unable to read from the SD card. Try a new SD card.
        djthumaundefined 1 Reply Last reply Reply Quote 0
        • djthumaundefined
          djthuma @dc42
          @dc42 Thank you for the info!
          I will try that first.
          Thank you
