    Feature request: Better information for error codes
    Duet Web Control
    405
    • ericlmccormickundefined
      ericlmccormick
      Darning prints, I get a lot of error/warning codes. Things such as "Warning: Obsolete use of S parameter on G1 command. Use H parameter instead." or "Error: invalid input type". Request that these events also note the file name and line that triggered this event.
      fcwiltundefined 1 Reply Last reply Reply Quote 1
        ericlmccormick
        As a follow-up I get the following error "M98 P"0:/macros/Filament Change"
        This is the GCode for that macro, but I don't use the S or H on the G1 commands.
        M104 S230 ; set extruder temp
        G28 ; Home Bed
        G1 X80 Y80 Z50 ;Move to Center
        M109 S230 ; wait for extruder temp
        G1 E10 F500
        G1 E-100 F6000
        G92 E0
        M291 P"New Filament Loaded?" S2
        G1 E150
        G92 E0
        G1 E-0.5 F500 ; Retract a little
        M104 S0 ; turn off temperature
        M84 ; disable motors
          jay_s_uk @ericlmccormick
          @ericlmccormick its probably coming from the G28 i.e. from your homing files
          ericlmccormickundefined 1 Reply Last reply Reply Quote 0
            ericlmccormick @jay_s_uk
            @jay_s_uk I don't have S in any of the G1 line of my homing files. I don't specifically call out H0 because H0 is supposed to be the default, but do I need H0 in each of the G1 lines?
              @ericlmccormick can you post your homing files and we can take a look (include homeall.g as well as individual axis homing files)
              • fcwiltundefined
                fcwilt @ericlmccormick
                @ericlmccormick
                I agree.
                It's sometimes quite hard to determine what file contains the error.
                The expanded features, like conditional code and variables, have resulted in a increased number of files on my printers, with one file calling another which may, in turn, call another.
                Having the filename appear in the error message would be a great help.
                  dc42 administrators @fcwilt
                  @fcwilt reporting the filename will require additional memory to be allocated, so we may add it to Duet 3 firmware in future but probably not to Duet 2 firmware. We already report the line number and often the column number in the error message.
                  • fcwiltundefined
                    fcwilt @dc42
                    Thank you for the reply.
                    I switched over to v3 hardware a while back. I only have two printers with v2 hardware. They will be upgraded as funds allow.
                    I am fairly certain that when you consider one .G file invoking several others and they in turn may invoke others, that knowing the line/column numbers still leaves are certain amount of "detective" work to figure what file generated the error.
                    Looking forward to the future.
                      @fcwilt yes I am aware that when using nested macros, it can be tricky to determine which one provoked an error message. The use of nested macros also increases the amount of memory we will need to store the filenames, because we will need to store the full paths of all the macros in the call stack.
                      fcwiltundefined Chrissundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @dc42
                        @dc42 said in Feature request: Better information for error codes:
                        Understood.
                        But even knowing the name of the file where the error occurred, regardless of the chain of calls, would be of great help.
                        Most of my errors are typos or syntax errors - few are of the "what the heck is going on" type.
                        Thanks.
                        • Chrissundefined
                          Chriss @dc42
                          @dc42 The filename would be already very helpful.
                          https://forum.duet3d.com/post/332495
                          I would not expect that there are tons of duplicate file names in real live. And it would be acceptable to go trough 5 files. But going trough more than 50 is a nightmare. And I had the problem that RRF was complaining about spaces and widespaces in one line. There is almost no way to grep for that. A "debug mode" maybe? You can free up some memory by dropping a lot of things, I guess that 90% of the problems appear before the actual g-code gets executed. So why not simulating the entire process with more debug info?
                          Or just store the filename in a variable and print it out with the error message. Just something which gives us a better hind. I add M118s to every file at the moment to trace down the location of the "typo".
                          Cheers, Chriss
