DWC error - HTTP request :Page not Found
I'm currently trying to make my Duet 3 5mini work.10min ago i could connect to the board via DWC.
I tryed to do a reboot of the SD Card to start again with a clean configuration and file structure. And my DWC page seems not working with a HTTP Request : Page not found error.
I have tested several things via YAT.
M122 FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2022-03-15 18:59:17 M21 SDHC card mounted in slot 0, capacity 7.95Gb M20 P/www Begin file list NONE End file list ok Last output is strange, because i've verified and I got the all the required file in the /www folder on the SD Card.
Is there something else i could check.
Regards,
@reFlexlab best post a screenshot of the root of the sd card and the www folder.
Also worth updating the firmware to 3.4.6 -
What filesystem is the SD card formatted with now?
