Array index out of bounds error on object model node
@dc42 Yes I have them. This is not a new installation. I re flasehd the image with a new sd card (the other was too old and giving problems)
This daemon file was the old one, no change at all.
heater 0 is my chamber, heter 1 is T0 heater 2 is T1 -
@Tinchus
My guess is daemon.g is starting to run before the heaters are defined in config.g
Try something like thisif state.status != "processing" if #heat.heaters = 3 ; edit to suit number of heaters you have in total if (heat.heaters[0].current > 60) | (heat.heaters[1].current > 65) | (heat.heaters[2].current > 65) | (heat.heaters[0].avgPwm > 0.01) M42 P3 S1 M42 P3 S1 else M42 P3 S0 G4 S2 else echo "Only " ^ #heat.heaters ^ " heaters initialized yet" -
@OwenD Im sure you are right about the reason, but solution is not working because the status whuile the error is being reported is "idle". As I have posted on another topic, what I see is that seems like config.g is not being fully processed?
When error happens, in DWC the re is no tool configured, heaters, nothing... and status is "idle".
If I click on config.g, and save it and confirm the restart, everything goes normal again.
My guess real problem is the raspi image version Im using. 32 bit full version doesnt work, image is not bootong. 32 bit lite works, but not usefull for me because I have a touch screen connected.
So Im using the 64 bits full version.
I have a raspi 3 B+
What do you think? -
@Tinchus
The code I wrote will work when the status is idle, however I had a typo (now fixed).
I had#heat.heater
instead of#heat.heaters
I don't run SBC, so I have no idea on that. -
@OwenD Yes! I didnt noticed the typo either. Ok, will add this and try it further but question remains regarding why is this happening, it started after falshing the new raspi image and version 3.5.2. Can you confirm there should not be a problem using the 64 bit version on my raspi? because there are other problem like for example DWC not starting on my touch screen, there is just a linux desktop instead (DWC working through web interface conncection)
