Need to remap my corexy X axis to E1 motor
  • I suspect my X-axis driver is dying and want to remap it to use the E1 motor.
    I tried this but now the X+10 moves X and Y and Y+10 does exactly the same
    [c]M584 X4 Y1 Z2 E3;[/c]
    ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
    ; generated by RepRapFirmware Configuration Tool on Sun Dec 10 2017 14:24:02 GMT+0000 (GMT Standard Time)
    M584 X4 Y1 Z2 E3;
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M667 S1 ; Select CoreXY mode
    M208 X300 Y275 Z300 S0 ; Set axis maxima
    M574 X1 Y2 Z1 S0 ; Set active high endstops
    M569 P4 S1 ; Drive 4 goes forwards
    M92 X80 Y80 Z1120 E400 ; Set steps per mm
    M350 X16 Y16 I1 ; Configure microstepping with interpolation
    M350 Z16 E16 I0 ; Configure microstepping with interpolation
    M566 X1000 Y1000 Z200 E400 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000 Y12000 Z2400 E24000 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z10 E400 ; Set max accelerations (mm/s^2)
    M204 P1200.000 T1600.000 R800.000 ; more acceleration
    M906 X1050 Y1050 Z1050 E840 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
    M563 P0 D0 H1 F2; Define tool 0
    M550 PGecko ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S1 ; Enable FTP
    M586 P2 S1 ; Enable Telnet
    M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    T0 ; Select first tool
    ;BLTouch
    M307 H3 A-1 C-1 D-1 ;
    M558 P5 X0 Y0 Z1 H5 F320 T6000; F probe speed - T Travel speed
    G31 X30 Y5 Z0.6 P25
    ;INCREASE VALUE WILL LOWER NOZZLE CLOSER TO THE BED, DECREASE THIS VALUE WILL RAISE THE NOZZLE FROM THE BED
    M557 X40:260 Y40:260 S55   ; probe from X=20 to 280, Y=20 to 280mm with a mesh spacing of 65mm
    M501
  • If all you've done is move the connector and then re-map the drive, then you probably need to reverse the motor direction for the drive that you have just moved using M569. You are quite sure that you didn't update the firmware from an earlier version than 1.19 at the same time yes? To be safe, follow the instructions here https://www.duet3d.com wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer
    Edit….......or it could be a bad crimp on the stepper connector that got dislodged when the plug was moved.
  • I have updated, but why would that matter?
    The M584 command can be after the M569 commands in config.g, must be before other commands that apply to drivers such as M906 and M350. Otherwise those commands won't be applied to the new X motor driver.
  • @totalitarian:
    Because the release notes say this:
    Important! On a CoreXY machine, if upgrading from a version prior to 1.19beta9, you need to reverse the Y motor direction in the M569 command. Similarly for CoreXYU machines.
  • Ah I see, sorry I was already on 1.19 and went to 1.20rc1.
  • @dc42:
    It's at the top, so is that OK?
  • @totalitarian:
    @dc42:
    Your config.g looks fine to me. Are you still having problems? If so check movement as per the link I posted. If only one motor turns, movement will be at 45 degrees. Going back to your original post, I note that you suspected that your X axis driver was dying. Maybe it's the motor or wiring and not the driver? But then, what was happening that made you suspect a faulty driver?
  • Sorted it. Plugged the motor into the wrong socket!!!
  • @totalitarian:
    Oops! We've all done similar but it take real man to admit it. đŸ™‚
