Failed to enable endstops
Hi, I'm trying to add auto-leveling to a 3D printer with a Duet 2 Ethernet. I've got everything up and running, but when I attempt to print, I encounter the "Failed to enable endstops" error. I've looked up solutions in the forum, but nothing seems to work. I hope someone can help me identify and resolve the error I'm facing.
This is a fairly old machine from 2016, and they've updated the firmware to RRF 3.3. I've checked that the config file was correctly updated.
Everything seems to work; I can move the axis, home all the axis, auto-level the bed, and heat the extruder and bed. However, if I try to print, I encounter the error.
Thanks in advance.
My config.g
; Configuration file for Duet (for firmware version = 3.3) ; Executed by the firmware on start-up ; Generated by INDART3D on 2022.01.19 ; General Preferences M575 P1 S1 B57600 ; Set serial comms parameters G90 ; Set to Absolute Positioning M83 ; Set extruder to relative mode M550 P"BF 500" ; Set Name ;M551 P"password" ; Set Password ; Duet Ethernet electronics (only for electronics with Ethernet) ;M540 PDE:AD:BE:EF:CA:FE ; Set MAC address (ONLY IF NECESSARY) ;M552 P192.168.1.114 ; Set IP address ;M554 P192.168.1.255 ; Set Gateway and/or DNS server ;M553 P255.255.255.0 ; Set Netmask ; Network M552 S1 ; Enable/disable network interface M586 P0 S1 ; Configure network protocols: Enable HTTP M586 P1 S0 ; Configure network protocols: Disable FTP M586 P2 S0 ; Configure network protocols: Disable Telnet ; Drivers M569 P0 S0 ; Set motor driver direction M569 P1 S1 ; Set motor driver direction M569 P2 S1 ; Set motor driver direction M569 P3 S1 ; Set motor driver direction M584 X0 Y1 Z2 E3 ; Set drive mapping M350 I1 X16 Y16 Z16 E16 ; Set microstepping mode M92 X100 Y100 Z1784 E400 ; Set axis steps per unit ;M566 X900 Y900 Z80 E8000 ; Set allowable instantaneous speed change M566 X300 Y300 Z80 E200 ; Set allowable instantaneous speed change GVIDAL M203 X9000 Y9000 Z400 E9000 ; Set maximum feedrate (mm/min) ;M201 X1800 Y1800 Z200 E8000 ; Set max acceleration (mm/s^2) M201 X800 Y800 Z150 E2000 ; Set max acceleration (mm/s^2) GVIDAL ;M906 I30 X1360 Y1550 Z1360 E1360 ; Set motor currents (mA) ;GVIDAL -MOTOR M906 X1360 Y1450 Z1300 E650 I70 M84 S60 ; Set Idle Time-out ; Axis limits M208 S1 X0 Y0 Z-3 ; Set axis min travel M208 S0 X500 Y495 Z500 ; Set axis max travel ; End stops M574 X1 S1 P"xstop" ; Set endstop configuration M574 Y1 S1 P"ystop" ; Set endstop configuration ;M574 Z1 S1 P"zstop" ; Set endstop configuration ;M574 Z1 S2 P"zstop" ; Set endstop configuration ;;M950 J1 C"!e0stop" ; Create GPIO/servo pin ;M581 P1 T2 R1 ; Configure external trigger#.g ; Z-Probe M558 P5 C"^zprobe.in" H5 F120 T6000 ; BLTOUCH probe speed mm/min M307 H3 A-1 C-1 D-1 M280 P3 S10 I1 G31 X22 Y0 Z3 P15 ; old biqu bed G31 X-44 Y0 Z2.8125 P25 ; G31 X-44 Y0 Z3.257 P25 3.888 M950 S0 C"exp.heater3" ; Set BL-Touch Tigger to be activated from Heater 3 pin M557 X50:450 Y50:450 S100 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; Set or report sensor parameters M950 H0 C"bedheat" T0 ; Create heater pin M143 H0 S125 ; Maximum heater temperature M307 H0 B1 S1.00 ; Set or report heating process parameters M570 H0 S0 P300 T15 ; Configure heater fault detection M140 H0 ; Set Bed Temperature (Fast) or Configure Bed Heater M308 S1 P"e0temp" Y"thermistor" R4700 T100000 B4725 C7.06e-8 A"HEATER" ; Set or report sensor parameters M950 H1 C"e0heat" T1 ; Create heater pin M143 H1 S300 ; Maximum heater temperature M307 H1 B0 R5.136 C59.7 D3.89 S1.00 V24.1 ; Set or report heating process parameters M302 P0 S160 R160 ; Allow cold extrudes M308 S10 Y"mcu-temp" A"MCU" ; Set or report sensor parameters M308 S11 Y"drivers" A"Drivers" ; Set or report sensor parameters M308 S12 Y"dhthumidity" A"Humedad" ; Set or report sensor parameters ; Fans M950 F0 C"fan0" Q500 T1 ; Create fan pin M106 P0 S1 T45 H1 C"Fan Tool" ; Set fan configuration M950 F1 C"fan1" Q500 ; Create fan pin M106 P1 S0 H-1 C"Layer Fan" ; Set fan configuration M950 F2 C"fan2" Q500 ; Create fan pin M106 P2 C"LED" S255 ; Set fan configuration M950 F8 Q500 C"e1heat" T1 ; Crea la salida para el filtro a 500Hz M106 P8 S1 T160 C"Filter" H1 ; Set fan configuration ; Tools M563 P0 D0 F1 H1 S"DART" ; Define tool G10 P0 X0 Y0 Z0 ; Set workplace coordinate offset or tool offset G10 P0 R0 S0 ; Set initial tool temperature ; Global Variables (not modifiable) global delete = 0 ; Global variable declaration "runonce.g" global respuesta = false ; Global variable declaration "mensajes.g" global titulo = "titulo" ; Global variable declaration "mensajes.g" global mensaje = "mensaje" ; Global variable declaration "mensajes.g" global cargaL = 1400 ; Global variable declaration global E0active = 0 ; Global variable declaration global E0standby = 0 ; Global variable declaration ; Modifiable by user ;M912 P0 S-6 ; Set electronics temperature monitor adjustment G29 S1 ; Load the height map from file and activate mesh bed compensation ;M21 P1 ; Initialize external SD card ;M291 P"Visit our <a href=""https://indart3d.com"" target=""_blank"">website</a> for more information" R"Welcome to INDART3D" S1 T29 ; Display message ; Always at the end M911 S22 R23 P"M913 X0 Y0 Z0 E0 M28""0:/sys/runonce.g"" M98 P""run.g"" M29 M400" ; Configure auto save on loss of power M501 ; Read stored parameters T0 P0 ; Tool selection by default
My homex.g
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Nov 07 2023 13:21:36 GMT+0100 (hora estándar de Europa central) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-500 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-500 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning G92 X0
My homey.g
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Nov 07 2023 13:21:36 GMT+0100 (hora estándar de Europa central) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning G92 Y0
My homez.g
G91 ; relative position G1 Z9 F6000 S2 ; raise z by 9 G90 ; absolute position G1 X228 Y250 F6000 M280 P3 S160 T1 M280 P3 S10 T1 G30 G1 Z20 F1000 M280 P3 S160 T1
@Makergal3D you're using S2 to try and move Z rather than H2 in your homez
@jay_s_uk thanks for your answer I change that but that was not the problem. It keep saying Failed to enable endstops
@Makergal3D can you post the output of
M98 P"config.g"
@jay_s_uk said in Failed to enable endstops:
M98 P"config.g"
That's it
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Heater 3 not found Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C Error: in file macro line 99 column 16: meta command: variable 'delete' already exists
@Makergal3D whats in your homeall.g?
@jay_s_uk yes it was the homeall.g they had something weird there, I changed for the code the configurator generates and start printing. thanks
