Error on tool heater M568
[RESOLVED]
Hi All, getting this issue when using the Duet Web Interface after upgrading to a BLTouch. "M568 P0 A2 - The M568 command is no longer needed." when trying to turn on the heater for tool 0 or when trying to pre-heat.
My config nor pre-load, load, or unload, have any references to M568 so I'm at a bit of a loose end. I don't think it's to do with the bltouch but possibly something to do with the firmware & web interface version?
I used the Reprap Config Tool version v3.3.16 and am running Duet Web Control 3.4.6 and board firmware RepRapFirmware for Duet 3 Mini 5+ 3.2 (2021-01-05)
I can provide a screenshot of the error and a copy of the config.g file but I don't know how to upload them here yet! Edit: Added config.g ! Tried to link screenshot.
Thanks in advance all!
Link to image on google drive. Any suggestions on how to embed?
; Configuration file for Duet 3 Mini 5+ (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun Oct 29 2023 13:22:55 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Locke Printer" ; set printer name ; Network M551 P"***********" ; set password M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes backwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E3600.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z200.00 E2500.00 ; set accelerations (mm/s^2) M906 X600 Y600 Z600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y25 Z0 S1 ; set axis minima M208 X215 Y235 Z260 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in M574 Y1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in M574 Z1 S2 ; Use zprobe ; Z-Probe M950 S0 C"io3.out" ; Set Z probe PWM Out M558 P9 C"io3.in" H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds G31 P500 X-50.25 Y-32 Z0.250; set Z probe trigger value, offset and trigger height M557 X0:165 Y55:220 P20 ; define mesh grid M280 P0 S90 ; send control signal to BLTouch through servo/gpio 0 ; Heaters M308 S0 P"temp0" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 R0.304 C431.4 D3.51 S1.00 V23.7 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R5.078 C181.2 D3.09 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit M143 H1 S250 ; set temperature limit for heater 1 to 250C ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 C"PARTFAN" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 C"HOTEND" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on ; Tools M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0 G10 P0 X0 Y32 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
@Maker-Emily-Locke you're running mismatched firmware between DWC and RRF. Update the firmware on your board to 3.4.6
DWC changed to using M568 -
@jay_s_uk It looks like that fixed it THANK YOU!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
