Drivers error short to ground - Multiple
@ZakariahMT said in Drivers error short to ground - Multiple:
https://drive.google.com/drive/folders/1WLIpfyeUcX1bzfJ1XoEwUPUMuUCRHnSZ?usp=sharing
There’s no config.g in that file set?
M122 straight after power on and before home axis
14/11/2023, 17:59:09 m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
Board ID: 0JD2M-9F8TA-GJ4TD-6J9FA-3SN6T-K7QA4
Used output buffers: 7 of 26 (18 max)
Static ram: 23836
Dynamic ram: 75368 of which 12 recycled
Never used RAM 10008, free system stack 184 words
Tasks: NETWORK(ready,11.9%,242) HEAT(notifyWait,0.0%,337) Move(notifyWait,0.0%,363) MAIN(running,84.1%,458) IDLE(ready,3.9%,30), total 100.0%
Owned mutexes:
Last reset 00:00:27 ago, cause: power up
Last software reset at 2023-11-14 17:11, reason: User, GCodes spinning, available RAM 10008, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 33.6, current 35.5, max 35.8
Supply voltage: min 23.7, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/114/4, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2023-11-14 17:59:08
Cache data hit count 1034103519
Slowest loop: 7.38ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 9.9ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0 sensor: no data received
=== Network ===
Slowest loop: 12.41ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.27
WiFi MAC address a4:e5:7c:03:b4:46
WiFi Vcc 3.41, reset reason Power up
WiFi flash size 2097152, free heap 23984
WiFi IP address 192.168.0.53
WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0M122 after home axis
14/11/2023, 18:02:29 m122
Used output buffers: 8 of 26 (24 max)
Static ram: 23836
Dynamic ram: 75440 of which 12 recycled
Never used RAM 9864, free system stack 120 words
Tasks: NETWORK(ready,14.1%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,304) MAIN(running,85.9%,458) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:47 ago, cause: power up
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 35.1, current 36.0, max 36.1
Supply voltage: min 23.6, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
Events: 3 queued, 3 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2023-11-14 18:02:28
Slowest loop: 11.99ms; fastest: 0.17ms
=== Storage ===
Free file entries: 9
SD card longest read time 0.5ms, write time 0.0ms, max retries 0
DMs created 83, segments created 3, maxWait 85625ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 11, completed 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
=== AuxDDARing ===
Segments left: 0
Movement lock held by HTTP
HTTP is idle in state(s) 2 15, running macro
Code queue is empty
=== Network ===
Slowest loop: 103.75ms; fastest: 0.07ms
= WiFi =
Failed messages: pending 0, notready 0, noresp 2
WiFi flash size 2097152, free heap 25448
Socket states: 0 0 0 0 0 0 0 0 -
That's odd
It's coming up on my end,
; Modix Big-60, Duex Expansion, Dual Printhead ; Configuration file for Duet WiFi (firmware version 3.4.5) ; Generated by Modix - Version 3.4.5 Config B global config_version = "Version 3.4.5 Config B" global generation = 3 ; Generation 3 printer global printhead = 1 ; Griffin printhead global expansion = 1 ; Duex expansion board is installed global printheads = 1 ; Dual printhead, change this value to 1 to switch it to a single-printhead setup ; General preferences_________________________________________________________ G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue) ; Network_____________________________________________________________________ M550 P"Big 60" ; set printer name ;M551 P"MODIX3D" ; Set password (optional) M98 P"config_networking.g" ; load networking settings G4 P300 ; wait 300ms ;M552 P0.0.0.0 ; Uncomment this command for using Duet Ethernet board ; Drives_________________________________________________________________________ ;Main board______________________________________________________________________ M569 P0 S0 ; Physical drive 0. X1 M569 P1 S1 ; Physical drive 1. X2 M569 P2 R-1 ; Physical drive 2. Disabled M569 P3 S0 ; Physical drive 3. Primary Extruder M569 P4 S0 ; Physical drive 4. Secondary Extruder ;Duex5 board_____________________________________________________________________ M569 P5 S0 ; Physical drive 5 . Y M569 P6 S0 ; Physical drive 6 . Z1 (0,600) M569 P7 S0 ; Physical drive 7 . Z2 (0,0) M569 P8 S0 ; Physical drive 8 . Z3 (600,0) M569 P9 S0 ; Physical drive 9 . Z4 (600,600) ;Motor to stepper motor driver mapping_________________________________________________________ M584 X0:1 Y5 Z6:7:8:9 E3:4 P3 ; Driver mapping M671 X-185:-185:668:668 Y668:-46:-46:668 S30 ; Anticlockwise ;Motor settings and acceleration limits___________________________________________________________________ M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z2000 E418.5:418.5 ; Set steps per mm M566 X360 Y360 Z30 E3600:3600 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X9000 Y9000 Z200 E5000:5000 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z200 E5000:5000 ; Set accelerations (mm/s^2) M204 P500 ; Set print and travel accelerations (mm/s^2) M906 X1800 Y1800 E1000:1000 Z1800 I50 ; Set motor currents (mA) and motor idle factor in per cent M84 S100 ; Set idle timeout - 100 seconds ; Axis Limits M208 X0 Y0 Z-2 S1 ; set axis minima M208 X600 Y600 Z660 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop + e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop ; Z-Probe M558 P9 C"zprobe.in" H3 F100 T9000 R0.5 ; BLTouch probing settings M950 S0 C"duex.pwm5" ; sets the BLTouch probe M376 H100 ; Height (mm) over which to taper off the bed compensation G31 P500 X-25.5 Y26.9 ; BLTouch X and Y offset M557 X{move.axes[0].min + sensors.probes[0].offsets[0] + 1, move.axes[0].max + sensors.probes[0].offsets[0] - 1} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 1, move.axes[1].max + sensors.probes[0].offsets[1] - 1} P10:10 ; The M557 is used to define the mesh grid area. It uses the P parameter to set the amount of probing points. P10:10 would be a 10x10 grid. Supports up to a 21x21 grid. M98 P"config_probe.g" ; Load the Z-offset from the config_probe.g file ; The Z_offset value is now set in config_probe.g, not in config.g ; Adjust the values there, do not adjust anything here. ; Heaters___________________________________________________________ M140 H-1 ; disable heated bed (overrides default heater mapping) ;E0_________________________________________________________________ ;M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin e0temp ;M308 S0 P"spi.cs1" Y"rtd-max31865" ; Configure sensor 0 as PT100 via the daughterboard M308 S0 P"e0temp" Y"pt1000" ; Configure sensor 0 as PT1000 on pin e0temp M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0 M98 P"PID_tune_E0.g" R1 ; PID calibration ; M307 is not used in this config. The M307 files are stored and executed from the PID_tune_E0.g file. You can verify the values there. M143 H0 S285 ; set temperature limit for heater 0 to 285C if {global.printheads} = 2 ;E1_________________________________________________________________ ;M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e1temp ;M308 S1 P"spi.cs2" Y"rtd-max31865" ; Configure sensor 1 as PT100 via the daughterboard M308 S1 P"e1temp" Y"pt1000" ; Configure sensor 1 as PT1000 on pin e1temp M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1 M98 P"PID_tune_E1.g" R1 ; PID calibration ; M307 is not used in this config. The M307 files are stored and executed from the PID_tune_E1.g file. You can verify the values there. M143 H1 S285 ; set temperature limit for heater 1 to 285C ; Fans______________________________________________________________ M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 C"Primary blower fan" ; set fan 0 value. Thermostatic control is turned on M950 F2 C"duex.fan7" Q500 ; create LED on pin fan2 and set its frequency M106 P2 S0 H-1 C"LED" ; Disable fan channel for LED M106 P2 S255 ; LED on by default M950 F3 C"duex.fan5" Q500 ; create fan 3 on pin fan1 and set its frequency M106 P3 S255 H0 T45 ; set fan 3 value. Thermostatic control is turned on if {global.printheads} = 2 M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0 H-1 C"Secondary blower fan" ; set fan 1 value. Thermostatic control is turned on M950 F4 C"duex.fan6" Q500 ; create fan 4 on pin fan1 and set its frequency M106 P4 S255 H1 T45 ; set fan 4 value. Thermostatic control is turned on ; Tools______________________________________________________________ ;T0_________________________________________________________________ M563 P0 S"E0 Primary" D0 H0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S210 ; set initial tool 0 active and standby temperatures to 0C if {global.printheads} = 2 ;T1_________________________________________________________________ M563 P1 S"E1 Secondary" D1 H1 F1 ; define tool 1 G10 P1 X0 Y74.3 Z0 ; set tool 1 axis offsets G10 P1 R0 S210 ; set initial tool 1 active and standby temperatures to 0C ; Automatic power saving____________________________________________ M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss. Power Failure Pause ; Filament sensor settings__________________________________________________ ;M591 D0 P1 C"duex.e2stop" S1 ; Regular filament sensor for E0 ;M591 D1 P1 C"duex.e3stop" S1 ; Regular filament sensor for E1 ; Add-on settings__________________________________________________ Primary hotend Clog detector__________________________________________________ M591 D0 P7 C"e1stop" S1 L3.2 E10 R10:300 Clog Detector E0 [Add-On] ;Secondary hotend Clog detector__________________________________________________ ;M591 D1 P7 C"zstop" S1 L3.2 E10 R10:300 ; Clog Detector E1 [Add-On] ; Crash detector__________________________________________________ ;M950 J2 C"duex.e4stop" ; create Input Pin 2 on pin E4 to for M581 Command. ;M581 P2 T0 S0 R0 ; Crash Detector [Add-On] ; Emergency stop button__________________________________________________ ;M950 J3 C"duex.e6stop" ; create Input Pin 2 on pin E4 to for M581 Command. ;M581 P3 T0 S1 R0 ; Emergency stop [Add-On] ;M581 P3 T1 S1 R1 ; Emergency stop, pause the print [Add-On] ;M581 P3 T1 S1 R0 ; Emergency stop, pause always [Add-On] ; Automatic Z Offset Calibration____________________________________ M574 Z1 S1 P"!duex.e5stop" ; configure switch-type for Automatic z-offset ;M501
@ZakariahMT Sorry, I'm seeing config.g now, I was looking on my phone earlier, somehow I missed it.
The error in the console is triggered by the lines here that should be commented:; Add-on settings__________________________________________________ Primary hotend Clog detector__________________________________________________ M591 D0 P7 C"e1stop" S1 L3.2 E10 R10:300 Clog Detector E0 [Add-On]
It needs a
in front of "Primary" and another between the end of the M591 command and "Clog Detector", ie; Add-on settings__________________________________________________ ; Primary hotend Clog detector__________________________________________________ M591 D0 P7 C"e1stop" S1 L3.2 E10 R10:300 ; Clog Detector E0 [Add-On]
That should fix the errors when running config.g.
For the motor error, it almost sounds like you have one motor that has shorted internally, and by moving it around, you're killing the drivers on the Duet. Check the resistance of each phase (pair of wires) of the motor that first exhibited the problem, at the connector where it connects to the Duet, and test each wire to ground, ie between the connector and the body of the motor. See https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_connecting#identifying-the-stepper-motor-phases to check motor wiring.
@droftarts I've gone through and fixed the config.g and now don't get the error which is good,
I've gone through again and double checked all the stepper motors for there resistance and continuity on the phases.
Stepper motor Resistance
X1 A2.1 B2.1
X2 A2.1 B2.1
E0 A1.9 B1.9
Y A2.2 B2.2
Z1 A2.6 B2.6
Z2 A3.1 B3
Z3 A3.1 B3.1
Z4 A2.6 B2.6I have continuity on each phase A1A2 and B1B2 for each motor and no continuity on A to B phase for each motor. This was checked at the connector end at the Duet and also on the motor pins with the connector off. I also checked each phase to the motor body and had no continuity.
Did you get a short-to-ground report while homing the axes?
Yeah they even appear with nothing connected to that driver. Modix Support said it may be the power supply with VIN to thr Duet but I've checked that with a multimeter.
When I have all the driver mapping standard as the config.g I can home the X axis but I get the event notification about driver one having a short right away even though it still moves and homes but then the Y motor won't move.
If I remap driver 5 (Y Axis) to driver 4 (E1 Axis in my case not in use) and home the printer the X Axis will home and the Y Axis homes but I get a two event notifications that drivers 1 and 4 have shorts and the Z axis won't home.
If I just hit the Z limit switch so then there homed I can Jogg the X and y axis fine with no event notifications but the Z won't move at all.
This is present on both boards, I have also reset the firmware and started from scratch with a different SD card to see if maybe that's a cause but the issue still persists.
I have tried different wiring looms with new stepper motors but the issues are still there.
I removed the boards from the printer and checked for any signs of magic smoke but none a are present
@ZakariahMT As the Z axis won't move and all those motors are on the Duex, try disconnecting the Duex by disconnecting the ribbon cable between them, and removing the power from the Duex. Then test the Duet on it's own.
You also have one driver with reporting disabled:
M569 P2 R-1
. Has this previously burnt out, or did you disable it when these problems started?Ian
It's Alive!
So i've narrowed down what the problem/problems was. The Duex board is dead to a degree. Not supplying voltage to any of the divers but is supplying voltage to everything else on the board like LED strip, griffin Z Puck and clog detector, the Duex is receiving 24v though. I was able to get a hand today from a mate who held the multimeter in the connectors of the axis while i hit home. We tested it against the X Axis which would home but the Y Axis had almost not voltage. We then tried it with the Z axis motors where i would trip the Y axis stop so the BL Touch would trigger and the Z Axis also showed no voltage.
So from there i then removed the Duex out and wired up everything to run off the Duet. I did the config.g for the Duet modix big 60 and it worked right away. I have also tested it with the old Duet2 that was in it and it is also working.
What is the warranty on the boards as i would like to get another Duex back into it so i can use tilt calibration in the future again. Thanks for the help and guidance!
@droftarts said in Drivers error short to ground - Multiple:
You also have one driver with reporting disabled: M569 P2 R-1. Has this previously burnt out, or did you disable it when these problems started?Also only just saw your message, for driver 2 it's not used and set to that in the Modix Big 60 V3 Duex Config folder.
@ZakariahMT It could just be the ribbon cable between the Duet and Duex is damaged, or one of the wires is making intermittent contact; have a good look at it. That would cause random driver errors, and possibly for the drives on the Duex to not enable. Plug it into the Duet and Duex, then measure resistance across the ribbon cable by testing at the pins on the back of the board. Check all the pins are soldered properly on each board too. There isn't much to go wrong on a Duex!
Are there any heater or motor wires running close to the ribbon cable? It can be susceptible to interference.
