Correct AC / Mains distribution here?
Hello everyone,
Is the way I distribute the Mains power here correct?
I am unsure of the following:
The position of the ground-fault circuit interrupter. Should it be before or after the switch?
The way I split / bridge the mains with the DIN terminal blocks. Is that the way to do it?
Context:
It's my first build, and it suddenly grew larger when I added a big pellet extruder with 4 x band heaters and a servo motor all using mains.I welcome any comments or advice you might have other than that.
Should I add a fuse on the heaters?Thank you so much!
Søren -
@sbNielsen I would go for one RCD on the mains input for protection as if it trips you now it's safe as the supply will be isolated, then use seperate circuit breakers for current protection, switches after theses, you may want to also fit an isolation switch for the mains supple .
