Toolboard 1LC extruder error.
Hi.
I'm new to RRF and currently learning to configure my printer Voron Trident 300mm. Wiring is compete and now I'm in testing phase. Configured sensorless homing. Now wanted to know if extruder rotates right direction and found out that extruder motor is not turning at all, thought that maybe motor is bad and switched motors. Still same, if I pres Extrude in DWC nothing happens. Everything else connected to the toolhead is working, parcooling fan, hotend fan, hotend thermistor, hotend heater, voron TAP.
Mainboard:
M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.6 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2023-07-21 14:09:13Toolhead:
M115 B121
Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33)here is my config.g
config.gIs it board TMC2209 problem or my configuration is not correct? Is there anything else I can test?
Jüri
@vaike_peeter How are you testing it? By sending an extruder movement command, eg G1 E10? Make sure you are sending moves in relative mode. Also extruder moves will be blocked if the hot end is not heated, or send
M564 H0
to allow the extruder to move while cold.Ian
@droftarts I heated up hotend to 250C and used Paneldue Extrusion section or DWC.
Now tested manually
toolhead 250CG91
G1 E10
nothing. Are these correct commands? -
@vaike_peeter I made full reset to my config and it started to work.
Thank you. -
