Github repo files for Duet2 V1.06?
Are the schematic and PCB files available in the Duet2 hardware repo for Duet2 V1.06 hardware?
I might be searching in the wrong place or maybe I shouldn't expect them to be there yet but i only see V1.04 and V1.05 project folders there.JD
@JD I presume you mean Duet v0.6. Try https://github.com/Duet3D/Duet-2-Hardware.
@dc42 Well, I'm not sure if there's some semantics about version numbers but I'm referring to Duet 2 PCB revision v1.06 as posted as a new version at the bottom of the Duet 2 docs page: https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview
but I'm not seeing it in that repository you've linked to, which is the same repository I was looking in before my question.Changes for the PCB revision V1.06 are listed there on the docs page as:
The following changes were necessary due to component availability issues, they do not result in functional changes to the design:.
Changed the 5V buck regulator to AP64200 due to part availability issues. Various passive component changes to support the new regulator. In addition the following improvements to the design were made:
Split the 5V rail into 5V_INT and 5V_EXT. this provides additional protection to some of the more sensitive components on the board from abuse in the form or feeding >5V into a 5V pin. Added TVS diodes to improve ESD protection Increase the pad size for the VIN screw terminal pins
@JD I'm sorry, I misread your post. I'll ask Tony to upload those files to Github.
@JD they are up there now.
https://github.com/Duet3D/Duet-2-Hardware/tree/master/Duet2/Duet2v1.06 -
@T3P3Tony Thanks so much!
