Solved block config [SBC mode]
Hi. Is there a way to block the edition of config.g file? I was thinking on loging in ssh and change permissions of the file. I tried that, changed the user to root and group to root (I know, not the best security practice but was just a test). I gave the file only reading permissions so the dsf user would still be able to read it, then I tried to edit the file through DWC and the edition was posible, I saved the file. I though it would not be possible... then in the ssh console I saw the user and group were reversed to dsf...
Ideas?
Thanks in advance.
Objective is to avoid students to change the configuration -
@Tinchus as you mentioned SSH I presume you are running the Duet with attached RPi or other Single Board Computer. Can you confirm that?
@dc42 Sorry, my bad. Im using duet3 in SBC mode (raspberry pi 3 B+), 6 printer on this config, rrf 3.4.6
@Tinchus I've asked @chrishamm to respond.
@Tinchus You should be able to remove the write flag for config.g (
sudo chmod -w /opt/dsf/sd/sys/config.g
via SSH), then nobody should be able to modify that file again. Users in standalone mode can remove the SD card, insert in a PC, and set the "read-only" flag for config.g using right-click -> file properties if they need a similar limitation. -
@chrishamm Hello. Thta was what I tried at second try: removing all W permissions (my forst try was to change the owner of the file to root).
None of both solutions worked, I can still modify the config.g throught the web interface, cant figure it out why, since the interface seems to be running under the dsf userAfter running the file is like this:
-r--r--r-- 1 dsf dsf 6129 Dec 11 15:55 config.g
After editing the file throught the web interface, permissions are somehow restored:
-rw-r--r-- 1 dsf dsf 6130 Dec 11 16:00 config.g
And if I change W permission and also the ownership to root and group root, edition is still posible but the file is moved into a backup:
-rw-r--r-- 1 dsf dsf 6129 Dec 11 16:03 config.g
-r--r--r-- 1 root root 6130 Dec 11 16:00 config.g.bak -
Solved: the solution is using the inmutable bit on the file
