M593 L parameter not working 3.5rc1++
With no L parameter in the config.g M593 command, the response to M593 at the console includes 'min. reduction 0.2', and printing with IS works smoothly. If a M593 L500 command is sent from the console, M593 from the console includes 'min. reduction 0.0', and the printer moves hesitantly, leaving surface blobs. It seems that sending M593 L with any number, or including an L parameter in the M593 command in config.g has the same effect.
Using rc1++(2023-12-07) on standalone duet2wifi, delta. -
@Adrian52 you are correct, there is a fault in the processing of the L parameter. Thanks for reporting it. I have fixed this in the forthcoming 3.5.0-rc.2 release.
undefined Exerqtor referenced this topic
