    Object model subscription - sometimes fails
    DSF Development
    659
    • Lemundefined
      Lem
      Hello!
      I would like to save some parameters during printing. I constantly read object model and save choosed values.
          while True:
              subscribe_connection = SubscribeConnection(SubscriptionMode.PATCH)
              subscribe_connection.connect()
              try:
                  object_model = subscribe_connection.get_object_model()
              finally:
                  subscribe_connection.close()
              layer_actual = object_model.job.layer
      But sometimes python script get stuck:
      ^CTraceback (most recent call last):
        File "print_loger.py", line 43, in <module>
        File "/home/pi/.local/lib/python3.7/site-packages/dsf/connections/subscribe_co                                  nnection.py", line 35, in get_object_model
          object_model = self.receive(ObjectModel)
        File "/home/pi/.local/lib/python3.7/site-packages/dsf/connections/base_connect                                  ion.py", line 77, in receive
          json_string = self.receive_json()
        File "/home/pi/.local/lib/python3.7/site-packages/dsf/connections/base_connect                                  ion.py", line 108, in receive_json
          part = self.socket.recv(BUFF_SIZE)
      Now I'm working on 3.4.6 version.
      What could be the reason of this behavior?
      • chrishammundefined
        chrishamm administrators @Lem
        @Lem Pressing emergency stop resets DCS and all connected IPC sockets.
        Duet software engineer
        Lemundefined 1 Reply Last reply Reply Quote 0
        • Lemundefined
          Lem @chrishamm
          @chrishamm Ok, but it's hard to recognize when script get stuck. Function get_object_model() don't raise any error... Beside this printing works properly so I wouldn't like to reset printer.
          chrishammundefined Falcounetundefined 2 Replies Last reply Reply Quote 0
            @Lem I'm sorry but I confirm that. The original DSF demo application shuts down properly when DCS is terminated on E-STOP. I'd expect the Python library to generate an event/error as well when the socket is closed. @Falcounet can you check this please?
            Falcounetundefined 1 Reply Last reply Reply Quote 1
            • Falcounetundefined
              Falcounet @chrishamm
              @chrishamm @Lem I'm going to look at this
                Falcounet @Lem
                @Lem I just releaseed a new version of dsf-python which raises an dsf.connections.exceptions.IPCSocketBrokenException exception when the IPC socket is closed.
                Please try and report back if you run in other problems.
                Lemundefined 1 Reply Last reply Reply Quote 3
                • Lemundefined
                  Lem
                  I've just implemented checking for an exception. I will let you know about the test results!
                  • Lemundefined
                    Lem @Falcounet
                    @Falcounet I think that your solution works - I can't register exception handling but I don't experience so many stucks. Did you improve something more? 😉 I will let you know if I am sure. But...
                    Function again gets stuck for ~3 min and I closed it. Problem appear in connect function this time.
                    DSF 3.4.6 and dsf-python-3.4.6.post4
                    Error:
                    • Lemundefined
                      Lem @Lem
                      The problem with get_object_model() has been resolved, but I'm still stuck with connect(). Can you add an exception in this function as well?
                      Falcounetundefined 1 Reply Last reply Reply Quote 0
                        Falcounet @Lem
                        @Lem said in Object model subscription - sometimes fails:
                        Given the traceback above, the socket is waiting to receive data so I guess a timeout is what is needed. Although the socket is currently in blocking mode so setting a timeout won't work.
                        Are you able to reproduce this problem ?
                        If so, please post a snippet I can use to try a fix.
                        • Lemundefined
                          Lem @Falcounet
                          @Falcounet Ok, I try to reproduce error and save snippet but probably I will post the same info like on photo above.
                          Apart from this, can you tell which way of object model subscription is the best?
                          Option 1:
                          if __name__ == "__main__":
                               subscribe_connection = SubscribeConnection(SubscriptionMode.FULL)
                               while True:
                                    time.sleep(1.0)
                                    if script_end == True:
                          Option 2:
                               while True:
                                    time.sleep(1.0)
                          Option 3:
                               while True:
                                    time.sleep(1.0)
