Duet Web Control Settings
Is there a way to save DWC settings on one browser and have them be remembered on any and all machine I open DWC on.
I set up a certain number of fans, plus ATX power control as well as the camera config, but I go to a different computer and all those settings are gone…it looks like all the settings are stored locally in a browser cookie of some sort
I actually have the same question. I only had a single temperature preset that I set on 1 browser and then went to another and it isn't there.
I had assumed those settings would be stored on the SD card.
I suggest you add this to the DWC wish list. The DWC settings are stored locally per browser.
+1, this is one of the most annoying "features" of DWC.
I use 4 different devices to access my printers and must setup each device/browser.
I changed the IP address of one the printers and guess what, yep you must setup everything again…
Posted this over on the DWC wish list - https://www.duet3d.com/forum/thread.php?pid=33190#p33190
