    How to format an int as a zero padded string?
    • zaptaundefined
      zapta
      Let's say that I have an int variable x >= 0 which I want to format as a zero padded 7 digits string, similar to "%07d" in some programming languages. For example 127 -> "0000127". Is there a simple way to achieve? Currently I am using the brute force code below.
      if global.x < 10
        set global.y = "000000" ^ global.x
      elif global.x < 100
        set global.y = "00000" ^ global.x
      elif global.x < 1000
        set global.y = "0000" ^ global.x
      elif global.x < 10000
        set global.y = "000" ^ global.x
      elif global.x < 100000
        set global.y = "00" ^ global.x
      elif global.x < 1000000
        set global.y = "0" ^ global.x
      else
        set global.y = "" ^ global.x
      echo "" ^ global.y
      zaptaundefined 1 Reply Last reply Reply Quote 0
      • zaptaundefined
        zapta @zapta
        Ok, this is simpler but I wonder if there is a single statement format solution.
        var decade = 10
        var result = "" ^ global.X
        while iterations < 6
          if global.X < var.decade
            set var.result = "0" ^ var.result
          set var.decade = var.decade * 10
        Alternatively, the iteration can be on the length of the string if these is a length function (?).
        • zaptaundefined
          zapta @zapta
          Ok, here is a simpler one. Took me some time to realize that the # unary operator require () to work.
          var pad = "" ^ global.x
          while #(var.pad) < 7
            set var.pad = "0" ^ var.pad
          fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @zapta
            @zapta
            Just out of curiosity why do you need to do this?
            Thanks.
            • zaptaundefined
              zapta @fcwilt
              @fcwilt, I am generating a unique id that is used to form a file name. Ideally would do it with a timestamp such as 231219-071453 but couldn't find a reliable way to generate it using gcode.
                dc42 administrators @zapta
                @zapta said in How to format an int as a zero padded string?:
                It works without the () for me, using RRF 3.5.0-rc.2.
                zaptaundefined 1 Reply Last reply Reply Quote 1
                • zaptaundefined
                  zapta @dc42
                  @dc42, must be fixed along the way. On 3.4.6 this is what i get
                  var x = "123"
                  echo "String: " ^ var.x
                  echo "Length: " ^ #var.x
