Duet 3HC Expansion looses Connection
i have 1 x Duet 6XD plus 3 x 3HC which all have the same RRF 3.5.0_rc2. The 3 x 3HC expansion boards loose connections and don't sync with 6XD . The expansion boards do not sync after reboot and they connect and disconnect. This is very frustrating to be honest after upgrade the 3 x 3HC expansion boards were visible and then when i rebooted again a day later the 3 x 3HC boards would not sync with 6XD at all . They have rapid red blinking LED which is different from the normal blinking LED when its synced and connected correctly.
@developeralgo222 most likely you either have a bad connection in the CAN wiring, or you have CAN termination resistors enabled on too many boards.
Try connecting just one 3HC with its termination jumpers fitted to the main board. If that works, connect another 3HC with termination jumpers fitted to the first one, and remove the jumpers from the first one. If that works, repeat for the third board.
If your main board and 3HC boards use different power supplies, you must tie the negative outputs of the power supplies together.
i have 1 x 24 V DC PSU with 3 x 3HC ( 3 different +24V terminals with 3 x Negative (0V) ) and the second 24V DC PSU with the main board.i have only 1 pair of CAN Termination jumpers (2) on the last board in the chain
@dc42 said in Duet 3HC Expansion looses Connection:
When I tried for a short time to power the Duet 3HC with 12V (while the 6HC was at 24V) I didn't have common negative and both were working (well: the 3HC was on and communicating the the main board, I didn't do much before attaching both to the same 24V power supply).
Currently i have moved All my Duets ----- Duet 6XD (has 2 external powered by another PSU drives so not consuming much current) and 3 x 3HC ---- onto a single 24V, 20A DC PSU.
i even made my own new RJ11 short cables to make sure they are correctly done and tested to be working correctly but all 3 x 3HC are not synchronizing with 6XD main board at all after upgrading to RRF 3.5.0_rc2
CAN ID 0 = 6XD ---- Input goes to CAN ID 1 -IN
CAN ID 1 = 3HC Board 1 --- CAN ID 1 OUT ---> CAN ID 2 IN
CAN ID 2 = 3HC Board 2 --- CAN ID 2 OUT ---> CAN ID 3 IN
CAN ID 3 = 3HC Board 3 with CAN Termination Jumpers in the chainI have started testing by connecting one 3HC board at a time. Duets are really becoming a frustrating endeavor or a labor of love. arrggh!!!!. . i don't have Atmel ICE tool. Will also try a factory reset using CAN ID resets method
Duet 6XD has a red LED blinking normally
Board 1 - 3HC has continuous Red LED blinking
Board 2 & 3 ( 3HC ) both have red LED blinking 2 times followed by a slight pause then 3 times then a pause and then repeats with the following error12/27/2023, 7:51:46 PM Error: Expansion board 3 reconnected 12/27/2023, 7:51:45 PM Error: Expansion board 2 reconnected Error: Expansion board 2 reconnected
Tested connecting each board itself and they work ok until i connect all of them and they stop working. If i leave a jumper Board 2 and 3 , somehow they seem to sync . Not sure why that would be the case . when i remove jumpers on board 1 and board 2 and only leave the one of board 3 , they don't sync at all
i will now try factory reset On Duet 3 Expansion 3HC, by setting all four address switches off and board should reset its address and CAN bus speed to default and request firmware from the main board. Tried this and that did not work either ?
undefined Phaedrux marked this topic as a question
@developeralgo222 I am wondering whether boards 2 and 3 are continually resetting. If you bypass board 1, can you get a M122 report from board 2 or board 3?
Does it make any difference if you change the order of the boards, or swap two of them over? For example, swap boards 1 and 3.
@developeralgo222 said in Duet 3HC Expansion looses Connection:
I was going to say "put all the firmware files on your mainboard and then set the switches of your expansion boards to 0000, one board connected at a time".
BTW: my RJ11 cable is just a 1.5m phone cable still bundled up from the packaging since it's too long, so length isn't a problem.
After following dc42's advice, double-check physical connections: I have an ethernet connection that sometimes disconnects my Duet from the PC (the clip in the cable broke, so the connector can loosen up, so in your case maybe the connector doesn't fit perfectly due to a shim of plastic or something) and once a Z motor didn't turn because, by moving the connection from the mainboard to the expansion, a connection wasn't set properly.
This post is deleted! -
Yes i think they are resetting every 1 second
12/29/2023, 2:02:03 PM Error: Expansion board 3 reconnected Error: Expansion board 3 reconnected 12/29/2023, 2:02:02 PM Error: Expansion board 2 reconnected Error: Expansion board 3 reconnected 12/29/2023, 2:02:02 PM Error: Expansion board 3 reconnected Error: Expansion board 2 reconnected 12/29/2023, 2:02:01 PM Error: Expansion board 3 reconnected Error: Expansion board 2 reconnected 12/29/2023, 2:02:01 PM Error: Expansion board 2 reconnected Error: Expansion board 3 reconnected 12/29/2023, 2:02:00 PM
@Mr-Yod said in Duet 3HC Expansion looses Connection:
i guess if the CAN connectors on the Duet 3 boards are RJ11 female then if you have RJ11 Male connector it should not be an issue , if the cables are wired correctly and yes sometimes you have a loose connection. I checked all that and nothing is working to have them synced
i have swapped the boards, Added each one by one but to no avail. The only way its able to Sync but disconnecting sometimes , is by having CAN jumpers on Board 2 & 3 ( 3HC expansion boards ) and No CAN jumper on Board 1 (3HC ). No sure why that would work somehow ?
The only difference between Board 1 & ( 2 or 3) is that board 2 & 3 have SMC NPN Vacuum Pressure Sensors connected to the IO pins and they are powered from the 3HC VIN & GND as per your earlier post suggestion and also Board 3 has CAN Termination Jumpers
@developeralgo222 if the boards are resetting once a second then I need a M122 report from one of them in order to determine why. So try powering up the system, let it run for a few seconds, then unplug some CAN cables to bypass one or two of the 3HC boards; then get a M122 report from the remaining one. It's electrically safe to connect and disconnected CAN cables while the boards are powered.
console_3HC1_But_both_3HC2-n-3HC3-with-CANTermJumpers.txt
console_Only_3HC1-with-CANTermJumpers_ByPassing_Both_3HC2_n_3HC3.txt
console_3HC1_n_3HC3-with-CANTermJumpers_Bypassing-3HC2.txt
console_3HC2_n_3HC3-with-CANTermJumpers_ByPassing-3HC1.txt
console_Only_3HC2-with-CANTermJumpers_ByPassing_Both_3HC1_n_3HC3.txt
console_Only_3HC3-with-CANTermJumpers_ByPassing_Both_3HC1_n_3HC2.txt
console_3HC1_3HC2_3HC3-with-CANTermJumpers.txt
NOTE: when i CAN connect only Duet 6XD to
3HC1 only with CAN Termination Jumpers on it (CAN ID 1 ) --- this works and synchronization occurs
3HC2 only with CAN Termination Jumpers on it (CAN ID 2 ) --- NO synchronization
3HC3 only with CAN Termination Jumpers on it (CAN ID 3 ) --- NO synchronization
3HC1 & 3HC2 only with CAN Termination Jumpers on 3HC2 --- NO synchronization
3HC1 & 3HC3 only with CAN Termination Jumpers on 3HC3 --- NO synchronization
3HC2 & 3HC3 only with CAN Termination Jumpers on 3HC3 --- NO synchronization
3HC1 & 3HC2 & 3HC3 with CAN Termination Jumpers on both 3HC2 and 3HC3 --- this works and synchronization occurs but there is an occasional timeout on 3HC1 . This should not be working as per Duet's documentation ???????
NOTE:
Also Duet 6XD, 3HC1 , 3HC2 & 3HC3 All share the same 24V , 20A DC Power Supply.
The only difference between 3HC1, 3HC2 & 3HC3 is that 3HC2 & 3HC3 each have 3 x SMC NPN Vacuum Pressure Digital Sensors -ZSE30A-01-N-L (Not Z-Probe) connected to them and share the Power VIN & GND Terminal on the Board itself as per @dc42 earlier suggestion
@developeralgo222 @dc42 can you respond to this issue ?
@developeralgo222 I know this sounds rather basic, but have you swapped the CAN wires around? It sounds like the cable from 3HC1 to 3HC2 isnโt working, or only partially, or picking up interference. Check continuity, and that resistance is within specification. How long are the cable runs?
@droftarts said in Duet 3HC Expansion looses Connection:
I have checked the RJ11 cables and tested them with a Fluke professional cable tester to make sure they are ok. The lengths are :
6XD to 3HC1 โ> 10 ft cable
3HC1 to 3HC2 & 3HC2 to 3HC3 โ> 1ft cableI am assuming that RJ11cable for CAN connection is supposed to be shielded Straight through cable ( ie wired at same pins positions on both ends ) as per the documentation . I was using high speed ADSL 2+ cable that were 10ft long , I tried also to shorten 2 of them to 1 ft but that did not solve the issue
@developeralgo222 @dc42 & @droftarts Finally got this fixed . The issue was bad cable /connection from 6XD to Expansion Board 1 of 3HC . Never trust any cables from China , OMG when i decided to splice them , they are really crappy no shields and no proper insulations per pair. Buyer be aware.Have seen this in many chinese made products on Amazon.
@developeralgo222 glad you got it fixed! Itโs been bugging me what it could be if it wasnโt the cables!
undefined Phaedrux has marked this topic as solved
Got them powered up and syncing and then they started rapid flashing and lost synchronization again. so i unplugged all the extension boards and again started adding one by one, to see if any board or cable is the problem. I made all the connection cables and tested them for continuity myself to make sure they are ok .
As per documentation , Is the 2 CAN Bus Termination Jumpers(resistors) required only on the Last Expansion Board in the chain ? In my Case 6XD --> 3HC(1) --> 3HC2(2) --> 3HC(3 -- Has 2 CAN Bus jumpers)
This is getting to be a frustrating episode
Yes, that should be correct. You should have termination at both ends of the bus.
