Bossa for firmware Install
Incase anyone has trouble installing Bossa (Used for PanelDue firmware) on a WIndows 10 64bit machine
you need to disable, Driver signature enforcement first then it will install.
You can also use the one included with the Arduino IDE.
Yes, I had trouble with bossac; it would not install properly on my win10. However, no install really needed; running exe from the command line worked without a problem.
